Hello all
When i configure vsphere input from one of our vcenter we got the following erorr
we have checked the vcenter all look good and the cert is ok
any advice how can i handle this error
telegraf version : 1.25.1
E! [inputs.vsphere] Error in plugin: Post “https://vc01.domain.com/sdk”: net/http: TLS handshake timeout
I would be hesitant to change a timeout if these are on the same network. It would indicate that something else is up with the connection or the settings between the vsphere and telegraf.
Since you are using https, are you using any custom certificates to access the vsphere? Are those added to the system’s keychain?
If you take a look at the vsphere readme there is a section in the config for custom SSL settings including certs. That is probably your best way forward.
