So I wanted to use InfluxQL, but the Installation failed, I followed the instructions of InfluxData, but after I downloaded the zip-file I wasn’t able to run the application. Does anyone has expieriences with such a problem?
I’m not aware of standalone InfluxQL (client) setups… Are you trying to install InfluxDB v1.8? which URL are you talking about?
