InfluxDB2 total Bucket Export to csv
currently i am trying to export my total Bucket to a csv File. I need it to import the Dataset to another Database.
I was reading a lot of influx export all --[flags]… but i am not sure which flags i should use for my export because the most commands in my CLI are not supported.
Currently i am using InfluxDB 2.7.1 as Docker container and i am looking forward to export it to a specific Path, that is mounted to the root Server.
I also tried to find something in the Web Interface of the DB but there was no option, that could solve my Problem.
I am looking forward, for some help.
Thank you very much!
Try the below command in CLI
influx export --buckets id
It will export the bucket with bucket id
the influx export is not working because its not actually exporting the Data.
I solved the Problem, with a Flux query to csv.
influx query ‘from(bucket: “YourBucketName”) |> range(start: -30d)’ --raw > daten.csv
If there is any other better option, pls share your thoughts.
@Sami Thanks, I was looking for the same functionality and your solution really helped me out.
One issue: Both types of quotes didn’t work for me when I copied/pasted them from this post. When I typed the single and double quotes myself, it did work. They differ from yours. This might be a locale issue.
Rudi
