Well, it seems I wasn’t far off. The command just needed double quotes around the CSV filename and the file was created.
The file was saved to: /var/lib/docker/overlay2/e0f90d754d64a352556729f08dc53978bbe1a03f91ba1b9d9b1f5bbb60ff65d2/diff
Usefully it contains the enhanced info in the start of the file, but then I noticed the data apears in “chunks”, each chunk beginning with its own headers (identical to all the other “chunks”), which means importing a sngle, flat csv from speedtest is going to be a challenge.
If it were mysql/mariadb, then the task would be easy but InfluxDB seems to have a logic all its own… The data is sourced from speeedtest-tracker GitHub), so it looks like I shall have to get back to them to see if their csv export is in any way compatible with the csv input requirements of InfluxDB2.
Ric
