Hy,
I have currently my influxDB v2 on a server, and would like to transfer it to another one.
I already installed the new influxDB on the second server, and I’m currently trying to transfer my buckets to this new one.
I saw on the documentation this page, and made some trials, without success.
Here is what I tried so far:
- Using
influxd inspect:
With following command line
influxd inspect export-lp --bucket-id xxx --engine-path ~/.influxdbv2/engine --ou
tput-path ExportTest.lp --compress
It correctly created the ExportTest.lp file, but weighted only 1kB. I’m not able to open/read this .lp file, but seems very lite to contain all the data.
- Using
influx export
With following command line:
influx export all --buckets MyBucket --org Datebook --file ExportTest
It also correctly create the ExportTest file, also weighted only 1KB. When I open it with notepad, it contain only this:
apiVersion: influxdata.com/v2alpha1
kind: Bucket
metadata:
spec:
So no bucket structure or data.
Can someone explain me what I did incorrect and how to correctly export the data from my current server?
Then I will try to import them on my server.
