DGR75
January 7, 2026, 4:10pm
1
I want to install InfluxDB on my Windows 11 PC.
On the page:
there’s a download “InfluxDB2 v2 (Windows)”
The download doesn’t start; I get the following message:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Code>NoSuchKey</Code>
<Message>The specified key does not exist.</Message>
<Key>influxdb/releases/v2.8.0/influxdb2-2.8.0-windows.zip</Key>
<RequestId>VERNZAT3EVFJR4GB</RequestId>
<HostId>WhcSclHA0MK+7/KlhYdnHLokgxgVZ82fUQ1iF0hhU11rMCpQreBzIoyrq6Arc0nb48dKAbVfUcI=</HostId>
</Error>
suyash
January 8, 2026, 10:53am
2
Hi @jdstrand could this be related to the key update change as well ? Thanks
@suyash - No. The XML doc isn’t talking about an .asc file but instead .zip and for a key rotation issue, I would’ve expected to see references to influxdb/releases/v2.8.0/influxdb2-2.8.0-windows.zip.asc.
If I use wget https://download.influxdata.com/influxdb/releases/v2.8.0/influxdb2-2.8.0-windows.zip (ie, the url at the aforementioned link), I get a 404. The InfluxData Downloads page 2 has the correct link, which is https://download.influxdata.com/influxdb/releases/v2.8.0/influxdb2-2.8.0-windows_amd64.zip .
I reported this here: https://docs.influxdata.com/influxdb/v2/install/ 'InfluxDB v2 (Windows)' link is broken · Issue #6715 · influxdata/docs-v2 · GitHub
DGR75
January 9, 2026, 1:14pm
4
This link works. Thank you.
