Hi,I download the lastest influxdb for windows 64bit binary ,
version is 1.3.6. when i unzip the zip file,i got five files but their name not ends with .exe. so double click to run influxd file is not working.
So i doubt if 1.3.6 infuxdb for windows ,the release file names is not correct,missing .exe for file extension. It is working ok, when i add .exe extension for file influxd . Or there is a new way to do that?
Also I have a question, I found no influx.conf file,and the data, wal, meta files are all stored in current users folders ,maybe just put a conf file in the zip package is better.
