I am new to using InfluxDB but am very eager to get it working in my lab.
I have just downloaded version 1.4.6 from this link Downloads
I have unzipped the file, but there are only binary files there.
I am unsure about how to proceed with the installation since there is no exectuable file, and have not found a solution online.
I would be very grateful for any help about how to proceed with this download (as in what to do with the binary files).
Thank you very much,
I believe the .exe was left off in the build process. Simply rename the files with the .exe extension and they should be fine.
dg
Hey David,
Thanks for the response. Should I rename all of the files with the.exe extension or just influxd?
Best,
-Karl
