influxdb v2.0 is not reading configuration file (config.toml file) in /etc/influxdb, but when running influxd print-config command it showed it is not reading the configuration file.
@Mamoona_Aslam are you setting INFLUXD_CONFIG_PATH=/etc/influxdb/config.toml in your process environment when running influxd?
