Is it possible to put a configuration file in the influxdb to read the constant variables
If you mean to configure influxd (the database server), yes. See InfluxDB configuration options | InfluxDB OSS v2 Documentation
If you mean a connection profile for the influx CLI, the CLI loads your credentials from a config file. You can use the --configs-path option to specify a different file. You can override those by setting environment variables in your shell. See influx - InfluxDB command line interface | InfluxDB OSS v2 Documentation
Edited: --configs-path
Sorry, the influx --configs-path option
