I’m running InfluxDB in Docker and get a consistent error when upgrading from 1.8.9 to 2.x. I’m sure I’m doing something stupid, but can’t find any reference to this issue.
I run Docker in upgrade mode as instructed in the upgrade instructions
docker create --name='Influxdb-v2-upgrade' \
-e TZ="America/New_York" -e HOST_OS="Unraid" -e 'TCP_PORT_8086'='8086' \
-e 'DOCKER_INFLUXDB_INIT_USERNAME'='<previous-admin-user>'
-e 'DOCKER_INFLUXDB_INIT_PASSWORD'='<previous-admin-password>' \
-e 'DOCKER_INFLUXDB_INIT_ORG'='home_assistant' \
-e 'DOCKER_INFLUXDB_INIT_BUCKET'='home_assistant' \
-e 'DOCKER_INFLUXDB_INIT_MODE'='upgrade' \
-v '<on influxdb path on host>':'/var/lib/influxdb':'rw' \
-v '<path of old influxdb.conf file>':'/etc/influxdb/influxdb.conf':'rw' \
-v '<new empty directoy for data>':'/var/lib/influxdb2':'rw' \
-v '<new empty directory for config>':'/etc/influxdb2':'rw' \
'influxdb:2.0'
The logs show
{"level":"info","ts":1633306969.0330784,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
{"level":"info","ts":1633306969.0341682,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
{"level":"info","ts":1633306969.036784,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/etc/influxdb2/config.toml"}
{"level":"info","ts":1633306969.0375338,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/meta","data":"/var/lib/influxdb/data"}
{"level":"info","ts":1633306969.0384605,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb2/influxd.bolt","engine":"/var/lib/influxdb2/engine"}
{"level":"info","ts":1633306969.094964,"caller":"bolt/bbolt.go:82","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb2/influxd.bolt"}
{"level":"info","ts":1633306969.1129034,"caller":"migration/migration.go:153","msg":"Bringing up metadata migrations","service":"migrations","migration_count":15}
{"level":"info","ts":1633306970.6485534,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/etc/influxdb2/influx-configs"}
{"level":"info","ts":1633306970.6487503,"caller":"upgrade/database.go:200","msg":"Checking available disk space"}
{"level":"info","ts":1633306970.8734708,"caller":"upgrade/database.go:221","msg":"Computed disk space","free":"424 GB","required":"9.6 GB"}
{"level":"info","ts":1633306970.8742876,"caller":"upgrade/database.go:50","msg":"Upgrading databases"}
{"level":"info","ts":1633306985.282964,"caller":"upgrade/database.go:193","msg":"Database upgrade complete","upgraded_count":2}
{"level":"warn","ts":1633306985.2834294,"caller":"upgrade/security.go:140","msg":"No buckets for database [home-assistant] exist in 2.x."}
{"level":"warn","ts":1633306985.2836392,"caller":"upgrade/security.go:140","msg":"No buckets for database [home-assistant] exist in 2.x."}
Error: upgrade: there were errors/warnings, please fix them and run the command again
See 'influxd -h' for help
2021-10-04T00:23:05.327335698Z warn cleaning bolt and engine files to prevent conflicts on retry {"system": "docker", "bolt_path": "/var/lib/influxdb2/influxd.bolt", "engine_path": "/var/lib/influxdb2/engine"}
I can see that the new data directory is filled during the migration process, then cleared when the process ends.
My main database I want to migrate data for is called home_assistant
. NOT* home-assistant
. I have a user named home-assistant
which has privileges configured on home_assistant
database.
Any ideas what might be happening here and how to resolve?
