Having trouble upgrading from 1.8.6 to 2.4. Below is the docker compose I used for 1.8.6 and 2.4 (latest). When the 2.4 container launches (after stopping the 1.8.6 container) and I watch the size of the influxdb2 folder it grows in size until it matched the size of the influxdb container and then it drops to 249KB. The logs says the upgrade was completed and the service is now running. I am able to login to http://localhost:8086 and login with the user ID and password. I am not able to login to the database with InfluxDB UI or connect to it with Grafana. I see no errors in the log.
At a loss where to go from here. Not sure if the migration is failing, if retention is set by default to seconds or minutes and data is being deleted after the upgrade, why authentication is failing…
I see numerous posts with users having issues with the upgrade from 1.x to 2.x, but none seem to be the same issue(s) I am having. Hoping someone can help.
Influxdb 1.8.6 docker compose
influxdb:
hostname: influxdb
image: influxdb:1.8.6
container_name: influxdb
restart: always
ports:
- "8086:8086"
- "25826:25826"
volumes:
- "${docker}/influxdb:/var/lib/influxdb"
- "${docker}/influxdb_backups:/var/lib/influxdb/backups"
- "${docker}/influxdb/influxdb.conf:/var/lib/influxdb/influxdb.conf:ro"
user: 1000:1000
Influxdb2 docker compose
influxdb:
hostname: influxdb
image: influxdb:latest
restart: always
environment:
- DOCKER_INFLUXDB_INIT_MODE=upgrade
- DOCKER_INFLUXDB_INIT_USERNAME=user
- DOCKER_INFLUXDB_INIT_PASSWORD=password
- DOCKER_INFLUXDB_INIT_ORG=my-org
- DOCKER_INFLUXDB_INIT_BUCKET=my-bucket
ports:
- "8086:8086"
- "25826:25826"
volumes:
- "${docker}/influxdb/influxdb.conf:/etc/influxdb/influxdb.conf:ro"
- "${docker}/influxdb2:/var/lib/influxdb2"
- "${docker}/influxdb2:/etc/influxdb2"
user: 1000:1000
