When I use “cargo build --release” to source build InfluxDB IOx on GitHub. “error: could not compile influxdb_iox (bin “influxdb_iox”)” always appears in the end.
I have tried using “cargo build” to compile into a debug mode, and it can be compiled successfully and executed normally.
Due to the requirement of performance testing, I would like to ask whether the InfluxDB IOx v.0.1 has not yet completed the release version, or there are other reasons.
Attached is my execution environment & complete error message
Static hostname: debian11
Chassis: vm
Virtualization: vmware
Operating System: Debian GNU/Linux 11 (bullseye)
Kernel: Linux 5.10.0-9-amd64
Architecture: x86-64
Caused by:
process didn’t exit successfully: /root/.rustup/toolchains/1.72.1-x86_64-unknown-linux-gnu/bin/rustc --crate-name influxdb_iox --edition=2021 influxdb_iox/src/main.rs --error-format=json --json=diagnostic-rendered-ansi,artifacts,future-incompat --diagnostic-width=80 --crate-type bin --emit=dep-info,link -C opt-level=3 -C lto=thin -C codegen-units=16 -C debuginfo=2 --cfg 'feature="default"' --cfg 'feature="jemalloc_replacing_malloc"' --cfg 'feature="tikv-jemalloc-ctl"' --cfg 'feature="tikv-jemalloc-sys"' -C metadata=d7f50078a8e59d79 -C extra-filename=-d7f50078a8e59d79 --out-dir /home/debian/influxdb/target/release/deps -L dependency=/home/debian/influxdb/target/release/deps --extern arrow=/home/debian/influxdb/target/release/deps/libarrow-0f1f46ef0fe289c1.rlib --extern arrow_flight=/home/debian/influxdb/target/release/deps/libarrow_flight-c906ee4dfde83a15.rlib --extern authz=/home/debian/influxdb/target/release/deps/libauthz-8f7d1e31484156e1.rlib --extern backtrace=/home/debian/influxdb/target/release/deps/libbacktrace-7b6ebb1a041144e8.rlib --extern bytes=/home/debian/influxdb/target/release/deps/libbytes-b1040e2f74a1c678.rlib --extern clap=/home/debian/influxdb/target/release/deps/libclap-06b92949f6bac2fd.rlib --extern clap_blocks=/home/debian/influxdb/target/release/deps/libclap_blocks-047a92e7686aa626.rlib --extern comfy_table=/home/debian/influxdb/target/release/deps/libcomfy_table-8c54690eb868ed2b.rlib --extern compactor=/home/debian/influxdb/target/release/deps/libcompactor-ee813e89e42ff728.rlib --extern data_types=/home/debian/influxdb/target/release/deps/libdata_types-a1c5d196dd0e0066.rlib --extern datafusion=/home/debian/influxdb/target/release/deps/libdatafusion-e4d095e2f5e0be30.rlib --extern dotenvy=/home/debian/influxdb/target/release/deps/libdotenvy-cc469b5bfe6bf82e.rlib --extern flate2=/home/debian/influxdb/target/release/deps/libflate2-cb5a7cfb0dade138.rlib --extern futures=/home/debian/influxdb/target/release/deps/libfutures-1ae82c988fc75355.rlib --extern futures_util=/home/debian/influxdb/target/release/deps/libfutures_util-2abc857d1045926f.rlib --extern generated_types=/home/debian/influxdb/target/release/deps/libgenerated_types-080c104def29e884.rlib --extern hashbrown=/home/debian/influxdb/target/release/deps/libhashbrown-dcb9fb3550db5e81.rlib --extern home=/home/debian/influxdb/target/release/deps/libhome-e6cf87d854601734.rlib --extern http=/home/debian/influxdb/target/release/deps/libhttp-24a8bfd0cda72f8e.rlib --extern humantime=/home/debian/influxdb/target/release/deps/libhumantime-428b74a0489b4062.rlib --extern import_export=/home/debian/influxdb/target/release/deps/libimport_export-7f2aee40b913cf82.rlib --extern influxdb_iox_client=/home/debian/influxdb/target/release/deps/libinfluxdb_iox_client-225de219c003f7b4.rlib --extern influxdb_storage_client=/home/debian/influxdb/target/release/deps/libinfluxdb_storage_client-db7da12a92a4e983.rlib --extern influxrpc_parser=/home/debian/influxdb/target/release/deps/libinfluxrpc_parser-da501687776cdd99.rlib --extern ingester_query_grpc=/home/debian/influxdb/target/release/deps/libingester_query_grpc-983606147f5d3733.rlib --extern iox_catalog=/home/debian/influxdb/target/release/deps/libiox_catalog-d95182afd16fae6d.rlib --extern iox_query=/home/debian/influxdb/target/release/deps/libiox_query-2bd4c4c3f7f55546.rlib --extern iox_time=/home/debian/influxdb/target/release/deps/libiox_time-f6349da74e50bd09.rlib --extern ioxd_common=/home/debian/influxdb/target/release/deps/libioxd_common-33582b2860a3df3e.rlib --extern ioxd_compactor=/home/debian/influxdb/target/release/deps/libioxd_compactor-3adbc6c631b67ce8.rlib --extern ioxd_garbage_collector=/home/debian/influxdb/target/release/deps/libioxd_garbage_collector-ed795baf4d33fc4c.rlib --extern ioxd_ingester=/home/debian/influxdb/target/release/deps/libioxd_ingester-79ba0e11fb2cf217.rlib --extern ioxd_querier=/home/debian/influxdb/target/release/deps/libioxd_querier-7c7699b0bb7a7543.rlib --extern ioxd_router=/home/debian/influxdb/target/release/deps/libioxd_router-d3c01314849760d5.rlib --extern ioxd_test=/home/debian/influxdb/target/release/deps/libioxd_test-d78e9cb167e688c7.rlib --extern itertools=/home/debian/influxdb/target/release/deps/libitertools-e31a775cbe227522.rlib --extern libc=/home/debian/influxdb/target/release/deps/liblibc-526466183952f84a.rlib --extern metric=/home/debian/influxdb/target/release/deps/libmetric-21924264b8842987.rlib --extern nu_ansi_term=/home/debian/influxdb/target/release/deps/libnu_ansi_term-64e2b922a17801f5.rlib --extern num_cpus=/home/debian/influxdb/target/release/deps/libnum_cpus-0b5491d7aa234cb8.rlib --extern object_store=/home/debian/influxdb/target/release/deps/libobject_store-30578ab125c22bb1.rlib --extern object_store_metrics=/home/debian/influxdb/target/release/deps/libobject_store_metrics-f34fe31880b21540.rlib --extern observability_deps=/home/debian/influxdb/target/release/deps/libobservability_deps-9149ec85119d2e41.rlib --extern once_cell=/home/debian/influxdb/target/release/deps/libonce_cell-0668b2f43c044e7a.rlib --extern panic_logging=/home/debian/influxdb/target/release/deps/libpanic_logging-72e5858a4c42c43c.rlib --extern parking_lot=/home/debian/influxdb/target/release/deps/libparking_lot-ed070fcddecc8da4.rlib --extern parquet_file=/home/debian/influxdb/target/release/deps/libparquet_file-306bfdbe5527ead3.rlib --extern parquet_to_line_protocol=/home/debian/influxdb/target/release/deps/libparquet_to_line_protocol-0d2fb41f4d7fdfdb.rlib --extern prost=/home/debian/influxdb/target/release/deps/libprost-9a7e4bee8ff6dcb5.rlib --extern rustyline=/home/debian/influxdb/target/release/deps/librustyline-d5a085409345fcb7.rlib --extern schema=/home/debian/influxdb/target/release/deps/libschema-572e2cc9c8d53144.rlib --extern serde=/home/debian/influxdb/target/release/deps/libserde-00fab36699373f0d.rlib --extern serde_json=/home/debian/influxdb/target/release/deps/libserde_json-23b203763d1cfd89.rlib --extern snafu=/home/debian/influxdb/target/release/deps/libsnafu-176a7d880c752f76.rlib --extern tempfile=/home/debian/influxdb/target/release/deps/libtempfile-b6dd0c04f59caa65.rlib --extern thiserror=/home/debian/influxdb/target/release/deps/libthiserror-a062eae9822be176.rlib --extern tikv_jemalloc_ctl=/home/debian/influxdb/target/release/deps/libtikv_jemalloc_ctl-36f496265c470091.rlib --extern tikv_jemalloc_sys=/home/debian/influxdb/target/release/deps/libtikv_jemalloc_sys-78b0b3b24926e216.rlib --extern tokio=/home/debian/influxdb/target/release/deps/libtokio-672635c4aea1eafb.rlib --extern tokio_stream=/home/debian/influxdb/target/release/deps/libtokio_stream-17dea05177ea1af4.rlib --extern tokio_util=/home/debian/influxdb/target/release/deps/libtokio_util-f59cbef1ec7a6ee3.rlib --extern tokio_metrics_bridge=/home/debian/influxdb/target/release/deps/libtokio_metrics_bridge-0927418c14a0f50f.rlib --extern tonic=/home/debian/influxdb/target/release/deps/libtonic-12553f3dfaf7c049.rlib --extern trace_exporters=/home/debian/influxdb/target/release/deps/libtrace_exporters-a9667ab22d426c6e.rlib --extern trogging=/home/debian/influxdb/target/release/deps/libtrogging-95b2f58ed14df67c.rlib --extern uuid=/home/debian/influxdb/target/release/deps/libuuid-884c41c71e52e3c9.rlib --extern wal=/home/debian/influxdb/target/release/deps/libwal-c25860f6dfe53618.rlib --extern wal_inspect=/home/debian/influxdb/target/release/deps/libwal_inspect-d9f469f35dc34781.rlib --extern workspace_hack=/home/debian/influxdb/target/release/deps/libworkspace_hack-a6939032640fcfc3.rlib --cfg tokio_unstable -C link-arg=-fuse-ld=lld -C link-arg=-Wl,--no-rosegment -C target-cpu=haswell -C force-frame-pointers=yes -L native=/home/debian/influxdb/target/release/build/ring-00bee0c17f63f356/out -L native=/home/debian/influxdb/target/release/build/bzip2-sys-0383cd77b0cc3d06/out/lib -L native=/home/debian/influxdb/target/release/build/lzma-sys-1713c98cefcf528e/out -L native=/home/debian/influxdb/target/release/build/zstd-sys-b1167be3f153e36a/out -L native=/home/debian/influxdb/target/release/build/lz4-sys-b364d836af08648e/out -L native=/home/debian/influxdb/target/release/build/blake3-45aa6c768bcf5fc8/out -L native=/home/debian/influxdb/target/release/build/blake3-45aa6c768bcf5fc8/out -L native=/home/debian/influxdb/target/release/build/libsqlite3-sys-b452ef5731cec07b/out -L native=/home/debian/influxdb/target/release/build/croaring-sys-97d4d58dbbbf67af/out -L native=/home/debian/influxdb/target/release/build/tikv-jemalloc-sys-56f46fd31988fe31/out/build/lib (signal: 9, SIGKILL: kill)
I would also like to confirm if there is any news about the InfluxDB Edge release version.
Thanks.
