hello guys
I am using influxdb 2.0 and .net unity3d (flux client is not compatible with Unity and cannot be used.)
I trying to insert some lines (bulk insert) into InfluxDB this is my code
for (i = 0; i < 100000; i++)
float posiRang_x = UnityEngine.Random.Range(100f, -100f);
float posiRang_y = UnityEngine.Random.Range(100f, -100f);
float posiRang_z = UnityEngine.Random.Range(-100f, 100f);
//string[] first = line.Split('\x020');
string pk = Guid.NewGuid().ToString("N");
//pointData = "Point,NAME=TEST,ID=" + pk + " X=" + first[0] + ",Y=" + first[1] + ",Z=" + first[2] + "\n";
//pointData = "Bulk_test_1t,NAME=TEST,ID=" + pk + " X=" + posiRang_x + ",Y=" + posiRang_y + ",Z=" + posiRang_z + "\n";
pointData = "Bulk_test_NoId,NAME=TEST X=" + posiRang_x + ",Y=" + posiRang_y + ",Z=" + posiRang_z + " 1617583075000000000\n";
data1.Add(pointData);
Debug.Log(i);
var chlist = string.Join(" ", data1);
Debug.Log(chlist);
var data = new StringContent(chlist, Encoding.UTF8, "application/json");
using (HttpResponseMessage response = await _httpClient.PostAsync(Url, data))
result = response.Content.ReadAsStringAsync().Result;
Debug.Log(response.StatusCode);
if ((int)response.StatusCode != 204)
Debug.Log(result.ToString());
Yet, when I do a count query in influxdb v2 UI, it shows that only the last line (count +1) was inserted.
Any idea on this?
- I canโt use flux client and library *
Thanks.
