Hello!
I have an issue inserting a Json-formatted string into influxdb 2 via line command and csv.
I exported from one measurement into csv, changed the measurement-name in excel and want to import the data via influx write to the database.
Export looks like:
#group,false,false,true,true,false,false,true,true
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,string,string,string
#default,_result,
,result,table,_start,_stop,_time,_value,_field,_measurement
,0,2023-01-01T04:07:53Z,2023-05-08T15:07:53Z,2023-03-28T06:37:06.408Z,“[”“2023-03-28 08:35:06"”,““2023-03-28 08:37:06"”,”“47"”,““48"”,”“1"”,““3919.525"”,”“3919.534"”,““17587.943"”,”“17587.95"”,““2"”,”“true”“,”“2346.97"”,““2347.002"”]”,value,measurement1
I want to import it again with:
influx write
–bucket the_bucket
–token the_token
–org the_org
–format csv
“#group,false,false,true,true,false,false,true,true
#default,_result,
,0,2023-01-01T04:07:53Z,2023-05-08T15:07:53Z,2023-03-28T06:37:06.408Z,[”“2023-03-28 08:35:06"”,““2023-03-28 08:37:06"”,”“47"”,““48"”,”“1"”,““3919.525"”,”“3919.534"”,““17587.943"”,”“17587.95"”,““2"”,”“true”“,”“2346.97"”,"“2347.002"”],value,measurement2
Somehow I am not able to deal with the double “” and the , in the string.
Can someone pls. tell me how I have to do this.
Thanks!
KR
