Hi everyone,
I’m experiencing challenges while trying to import CSV data into InfluxDB, and I hope to get some guidance or insights from the community.
Here’s the Background:
I have a dataset that I’m trying to import into InfluxDB using the influx write command. My CSV data is intended to include measurements from sensors, specifically for a Power Usage Measurement application. However, I keep running into errors during the import process.
Example CSV Structure:
Initially, the CSV structure I tried was formatted like this:
plaintext
#datatype measurement,tag,tag,double,dateTime:RFC3339
kWh,domain,entity_id,value,time
sensor,l1_raw_kwh,66666,2024-08-17T03:15:00Z
Error Encountered:
Despite structuring my CSV to reflect what I believed was correct, I received errors related to parsing and handling timestamps. The specific error I faced was:
text
Error: failed to write data: 400 Bad Request: unable to parse 'sensor,domain=sensor,entity_id=l1_raw_kwh value=66666 1723864500000000000': time outside range -9223372036854775806 - 9223372036854775806
This indicated an issue with the timestamp, suggesting it wasn’t being interpreted correctly by InfluxDB.
Attempts to Resolve:
- Confirmed the Correct Timestamp Format: Ensured that the timestamps were in RFC3339 format.
- Checked Header Consistency: Verified that the
#datatypeline in the CSV header matched the data that followed. - Incrementally Simplified Data: Attempted to write smaller datasets to see if that resolved the parsing issue.
- Used the Dry Run Command: Tried running the import with a dry run to see if it would process correctly without committing changes.
Despite these efforts, I continued to face the same issues, leading to significant frustration as I was unable to import the data as intended.
Request for Assistance:
I’m reaching out to seek advice or best practices on structuring CSV imports into InfluxDB. If anyone has faced a similar problem or has insights into what I might be missing, I would greatly appreciate your help.
Thank you for your time!
