How to write data in Influxdb using c#
0
I want to send data to Influxdb rest API v2. However, I get a 400 error and cannot send data. Because unity is being used, the corresponding influxDB.client library conflicts with assembly and cannot be used. How do I send data to influxDb 2.0 and write it?
this is my code
const string url = "http://localhost:8086/api/v2/write org=DT_navigator&bucket=test_bk&precision=s";
     async System.Threading.Tasks.Task WriteDataAsync()
      var json = JsonConvert.SerializeObject("mem,host=host1 used_percent=23");
      var data = new StringContent(json, Encoding.UTF8, "application/json");
    HttpClient client = new HttpClient();
    client.DefaultRequestHeaders.Add("Authorization", "Token " + token);
    var response = await client.PostAsync(url, data);
    string result = response.Content.ReadAsStringAsync().Result;
    Debug.Log(result);
and error message {β€œcode”:β€œinvalid”,β€œmessage”:β€œunable to parse β€˜β€œmem,host=host1 used_percent=23”’: invalid number”}
Since it looks like your data is already in Influx Line Protocol, you shouldn’t need to convert it to JSON before sending it to the write API
Hi there,
I am trying to do a similar thing. I am trying to send data remotely from C# code to influx DB 2.0. The health status on connection gives success but the data is not getting inserted into influxDB when I check on localhost:8086
Here is my code:
usingIoTHubTrigger=Microsoft.Azure.WebJobs.EventHubTriggerAttribute;
usingMicrosoft.Azure.WebJobs;
usingMicrosoft.Azure.WebJobs.Host;
usingMicrosoft.Azure.EventHubs;
usingSystem.Text;
usingSystem.Net.Http;
usingMicrosoft.Extensions.Logging;
usingSystem;
usingSystem.Text.Json;
usingSystem.Collections.Generic;
usingNewtonsoft.Json;
usingInfluxDB.Client;
usingInfluxDB.Client.Api.Domain;
usingInfluxDB.Client.Core;
usingInfluxDB.Client.Writes;
usingSystem.Threading.Tasks;
namespaceWatlow.Function
publicclassObject{​​​​​​​​
publicstringserial_number{​​​​​​​​get;set;}​​​​​​​​
publicfloatuniversal_input_1_mod_5{​​​​​​​​get;set;}​​​​​​​​
publicfloatuniversal_input_2_mod_5{​​​​​​​​get;set;}​​​​​​​​
publicfloatuniversal_input_3_mod_5{​​​​​​​​get;set;}​​​​​​​​
publicfloatuniversal_input_4_mod_5{​​​​​​​​get;set;}​​​​​​​​
publicstringdisplay_units{​​​​​​​​get;set;}​​​​​​​​
publicDateTimets{​​​​​​​​get;set;}​​​​​​​​
publicstaticclassIotHubDataProcessing
privatestaticHttpClientclient=newHttpClient();
[FunctionName(β€œIotHubDataProcessing”)]
publicstaticvoidRun([IoTHubTrigger(β€œmessages/events”,Connection=β€œConnectionString”)]EventDatamessage,ILoggerlog)
log.LogInformation($β€œC# IoT Hub trigger function processed a message: {​​​​​​​​Encoding.UTF8.GetString(message.Body.Array)}​​​​​​​​”);
Objectobj=JsonConvert.DeserializeObject(Encoding.UTF8.GetString(message.Body.Array));
WriteInflux(obj);
publicstaticasyncvoidWriteInflux(Objectobj)
conststringtoken=β€œpcSpeRibWx0Xak–KpLI23kk52LZDbPcRjKKpmtPqZ8l47_mlUMsrgG69XeSmchQ_apOWwmgh8CpN1QQ2oQTuQ==”;
conststringbucket=β€œtimeseriesDB”;
conststringorg=β€œxxxx”;
conststringpassword=β€œxxxxx”;
varclient=InfluxDBClientFactory.Create(β€œhttp://20.83.176.xxx:8086”,β€œxxxx”,password.ToCharArray());
varhealth=awaitclient.HealthAsync();
if(health.Status.ToString()==β€œPass”){​​​​​​​​
Console.WriteLine(β€œConnection success.”);
else{​​​​​​​​
Console.WriteLine($β€œ{​​​​​​​​health.Status}​​​​​​​​”);
Console.WriteLine($β€œConnection failure: {​​​​​​​​health.Message}​​​​​​​​!”);
varpoint=PointData
.Measurement(β€œtemperature”)
.Tag(β€œserialNumber”,obj.serial_number)
.Field(β€œtc1”,obj.universal_input_1_mod_5)
.Field(β€œtc2”,obj.universal_input_2_mod_5)
.Field(β€œtc3”,obj.universal_input_3_mod_5)
.Field(β€œtc4”,obj.universal_input_4_mod_5)
.Timestamp(DateTime.UtcNow,WritePrecision.Ns);
using(varwriteApi=client.GetWriteApi())
writeApi.WritePoint(bucket,org,point);
