How to insert data into InfluxDB from Azure Functions in C# (C-sharp)?
Hi there,
I have Azure functions in C# and and InfluxDB hosted on Azure cloud. I am trying to send data remotely from C# code to influx DB 2.0. The health status on connection gives success but the data is not getting inserted into influxDB when I check on localhost:8086
Here is my code:
usingIoTHubTrigger=Microsoft.Azure.WebJobs.EventHubTriggerAttribute;
usingMicrosoft.Azure.WebJobs;
usingMicrosoft.Azure.WebJobs.Host;
usingMicrosoft.Azure.EventHubs;
usingSystem.Text;
usingSystem.Net.Http;
usingMicrosoft.Extensions.Logging;
usingSystem;
usingSystem.Text.Json;
usingSystem.Collections.Generic;
usingNewtonsoft.Json;
usingInfluxDB.Client;
usingInfluxDB.Client.Api.Domain;
usingInfluxDB.Client.Core;
usingInfluxDB.Client.Writes;
usingSystem.Threading.Tasks;
namespaceWatlow.Function
publicclassObject{​​​​​​​​
publicstringserial_number{​​​​​​​​get;set;}​​​​​​​​
publicfloatuniversal_input_1_mod_5{​​​​​​​​get;set;}​​​​​​​​
publicfloatuniversal_input_2_mod_5{​​​​​​​​get;set;}​​​​​​​​
publicfloatuniversal_input_3_mod_5{​​​​​​​​get;set;}​​​​​​​​
publicfloatuniversal_input_4_mod_5{​​​​​​​​get;set;}​​​​​​​​
publicstringdisplay_units{​​​​​​​​get;set;}​​​​​​​​
publicDateTimets{​​​​​​​​get;set;}​​​​​​​​
publicstaticclassIotHubDataProcessing
privatestaticHttpClientclient=newHttpClient();
[FunctionName(β€œIotHubDataProcessing”)]
publicstaticvoidRun([IoTHubTrigger(β€œmessages/events”,Connection=β€œConnectionString”)]EventDatamessage,ILoggerlog)
log.LogInformation($β€œC# IoT Hub trigger function processed a message: {​​​​​​​​Encoding.UTF8.GetString(message.Body.Array)}​​​​​​​​”);
Objectobj=JsonConvert.DeserializeObject(Encoding.UTF8.GetString(message.Body.Array));
WriteInflux(obj);
publicstaticasyncvoidWriteInflux(Objectobj)
conststringtoken=β€œpcSpeRibWx0Xak–KpLI23kk52LZDbPcRjKKpmtPqZ8l47_mlUMsrgG69XeSmchQ_apOWwmgh8CpN1QQ2oQTuQ==”;
conststringbucket=β€œtimeseriesDB”;
conststringorg=β€œxxxx”;
conststringpassword=β€œxxxxx”;
varclient=InfluxDBClientFactory.Create(β€œ[http://20.83.176.xxx:8086](http://20.83.176.xxx:8086/)”,β€œxxxx”,password.ToCharArray());
varhealth=awaitclient.HealthAsync();
if(health.Status.ToString()==β€œPass”){​​​​​​​​
Console.WriteLine(β€œConnection success.”);
else{​​​​​​​​
Console.WriteLine($"{​​​​​​​​health.Status}​​​​​​​​");
Console.WriteLine($β€œConnection failure: {​​​​​​​​health.Message}​​​​​​​​!”);
varpoint=PointData
.Measurement(β€œtemperature”)
.Tag(β€œserialNumber”,obj.serial_number)
.Field(β€œtc1”,obj.universal_input_1_mod_5)
.Field(β€œtc2”,obj.universal_input_2_mod_5)
.Field(β€œtc3”,obj.universal_input_3_mod_5)
.Field(β€œtc4”,obj.universal_input_4_mod_5)
.Timestamp(DateTime.UtcNow,WritePrecision.Ns);
using(varwriteApi=client.GetWriteApi())
writeApi.WritePoint(bucket,org,point);
Thanks in advance.Preformatted text
Hi @raginigupta6,
thanks for using our client. Could you share debug output from client? You can enable debug mode by:
var client = InfluxDBClientFactory.Create("http://20.83.176.xxx:8086", _token.ToCharArray());
client.SetLogLevel(LogLevel.Body);
There are also small glitches in your code
  1. The client doesn’t supports initialization with array of urls. This is not valid:
You should use url and token:
  1. The better choice for your use case will be use a WriteApiAsync than WriteApi.
var point = PointData.Measurement("temperature")
    .Tag("serialNumber", obj.serial_number)
    .Field("tc1", obj.universal_input_1_mod_5)
    .Field("tc2", obj.universal_input_2_mod_5)
    .Field("tc3", obj.universal_input_3_mod_5)
    .Field("tc4", obj.universal_input_4_mod_5)
    .Timestamp(DateTime.UtcNow, WritePrecision.Ns);
Trace.WriteLine($"Data to write: {point.ToLineProtocol()}");
await client.GetWriteApiAsync().WritePointAsync(bucket, org, point);
Regards
Thank you so much, it’s working now :slight_smile: Thanks a lot!!
