Hi!
I want to send data from ESP32 using the Arduino libraries to InfluxDB Azure cloud. In order to check connections and getting familiar with Influx I first tried to use the basic example provided in the Data Arduino source section. Unfortunately sending data does not work. Connecting to influx database looks fine and seems to work!
The message Log of the serial monitor shows this:
> 17:34:54.870 → rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
> 17:34:54.870 → configsip: 0, SPIWP:0xee
> 17:34:54.870 → clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
> 17:34:54.870 → mode:DIO, clock div:1
> 17:34:54.917 → load:0x3fff0018,len:4
> 17:34:54.917 → load:0x3fff001c,len:1216
> 17:34:54.917 → ho 0 tail 12 room 4
> 17:34:54.917 → load:0x40078000,len:9720
> 17:34:54.917 → load:0x40080400,len:6352
> 17:34:54.917 → entry 0x400806b8
> 17:34:55.291 → Connecting to wifi
> 17:34:57.162 → Syncing time.
> 17:34:57.667 → Synchronized time: Tue Nov 3 17:34:57 2020
*> 17:34:57.667 → *
> 17:34:58.604 → Connected to InfluxDB: https://westeurope-1.azure.cloud2.influxdata.com
> 17:34:58.604 → Writing: wifi_status,device=ESP32,SSID=WLAN\ AP\ 2,4GHz rssi=-49i
*> 17:34:59.568 → InfluxDB write failed: *
> 17:34:59.568 → Wait 10s
> 17:35:09.540 → Writing: wifi_status,device=ESP32,SSID=WLAN\ AP\ 2,4GHz rssi=-51i
*> 17:35:10.542 → InfluxDB write failed: *
> 17:35:10.542 → Wait 10s
Data are not visible in the database. There’s also no error message shown.
#define INFLUXDB_CLIENT_DEBUG is uncommented but with no results as shown above.
Has anyone an idea?
BR
