madlan
March 19, 2022, 8:22pm
1
I’ve setup a test account using the cloud option (Google) and copied the example Arduino code to an ESP32, but get the below error.
INFLUXDB_URL, INFLUXDB_TOKEN, INFLUXDB_ORG and INFLUXDB_BUCKET appear correct.
INFLUXDB_URL = “https://europe-west1-1.gcp.cloud2.influxdata.com ”
INFLUXDB_ORG = InfluxDB UI → User → About → Common Ids → Organization ID.
INFLUXDB_BUCKET = “Test”
Connection with debug on:
Writing: wifi_status,device=ESP32,SSID=***** rssi=-54i
[599750][D][HTTPClient.cpp:298] beginInternal(): protocol: https, host: europe-west1-1.gcp.cloud2.influxdata.com port: 443 url: /api/v2/write?org=***********&bucket=TEST
[599760][D][HTTPClient.cpp:595] sendRequest(): request type: 'POST' redirCount: 0
[599767][E][WiFiClientSecure.cpp:135] connect(): start_ssl_client: -1
[599773][D][HTTPClient.cpp:1134] connect(): failed connect to europe-west1-1.gcp.cloud2.influxdata.com:443
[599782][W][HTTPClient.cpp:1437] returnError(): error(-1): connection refused
[599789][D][HTTPClient.cpp:405] disconnect(): tcp is closed
InfluxDB write failed: connection refused
Wait 10s
Any idea what I’ve done wrong?
@madlan , just to be sure, do you pass InfluxDbCloud2CACert to the InfluxDBClient constructor, and do you have time synchronization before writing data?
madlan
March 21, 2022, 11:57am
3
@VlastaHajek Thanks for replying, yes, time is synced correct:
Syncing time...
Synchronized time: Mon Mar 21 11:51:27 2022
Constructor is:
InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN, InfluxDbCloud2CACert);
Here is the full code:
#if defined(ESP32)
#include <WiFiMulti.h>
WiFiMulti wifiMulti;
#define DEVICE "ESP32"
#elif defined(ESP8266)
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti wifiMulti;
#define DEVICE "ESP8266"
#endif
#include <InfluxDbClient.h>
#include <InfluxDbCloud.h>
// WiFi AP SSID
#define WIFI_SSID "*********"
// WiFi password
#define WIFI_PASSWORD "*********"
// InfluxDB v2 server url, e.g. https://eu-central-1-1.aws.cloud2.influxdata.com (Use: InfluxDB UI -> Load Data -> Client Libraries)
#define INFLUXDB_URL "https://europe-west1-1.gcp.cloud2.influxdata.com"
// InfluxDB v2 server or cloud API token (Use: InfluxDB UI -> Data -> API Tokens -> Generate API Token)
#define INFLUXDB_TOKEN "**************************************"
// InfluxDB v2 organization id (Use: InfluxDB UI -> User -> About -> Common Ids )
#define INFLUXDB_ORG "******************"
// InfluxDB v2 bucket name (Use: InfluxDB UI -> Data -> Buckets)
#define INFLUXDB_BUCKET "TEST"
// Set timezone string according to https://www.gnu.org/software/libc/manual/html_node/TZ-Variable.html
// Examples:
// Pacific Time: "PST8PDT"
// Eastern: "EST5EDT"
// Japanesse: "JST-9"
// Central Europe: "CET-1CEST,M3.5.0,M10.5.0/3"
#define TZ_INFO "GMT+0BST-1,M3.5.0/01:00:00,M10.5.0/02:00:00"
// InfluxDB client instance with preconfigured InfluxCloud certificate
// Data point
Point sensor("wifi_status");
void setup() {
Serial.begin(115200);
// Setup wifi
WiFi.mode(WIFI_STA);
wifiMulti.addAP(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to wifi");
while (wifiMulti.run() != WL_CONNECTED) {
Serial.print(".");
delay(100);
Serial.println();
// Add tags
sensor.addTag("device", DEVICE);
sensor.addTag("SSID", WiFi.SSID());
// Accurate time is necessary for certificate validation and writing in batches
// For the fastest time sync find NTP servers in your area: https://www.pool.ntp.org/zone/
// Syncing progress and the time will be printed to Serial.
timeSync(TZ_INFO, "pool.ntp.org", "time.nis.gov");
// Check server connection
if (client.validateConnection()) {
Serial.print("Connected to InfluxDB: ");
Serial.println(client.getServerUrl());
} else {
Serial.print("InfluxDB connection failed: ");
Serial.println(client.getLastErrorMessage());
void loop() {
// Clear fields for reusing the point. Tags will remain untouched
sensor.clearFields();
// Store measured value into point
// Report RSSI of currently connected network
sensor.addField("rssi", WiFi.RSSI());
// Print what are we exactly writing
Serial.print("Writing: ");
Serial.println(sensor.toLineProtocol());
// Check WiFi connection and reconnect if needed
if (wifiMulti.run() != WL_CONNECTED) {
Serial.println("Wifi connection lost");
// Write point
if (!client.writePoint(sensor)) {
Serial.print("InfluxDB write failed: ");
Serial.println("Wait 10s");
delay(10000);
Thanks a lot for the info.
Did the validation connection finish correctly?
What is your ESP32 Arduino Core version?
madlan
March 21, 2022, 1:11pm
5
I’m using Arduino IDE 1.8.19 and 2.0.2 ESP32 Core (I’ve just done a clean install of both):
Here is the full output, seems connected ok?
[2-hal-cpu.c:211] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[ 37][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 0 - WIFI_READY
[ 129][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 2 - STA_START
[ 129][I][WiFiMulti.cpp:84] addAP(): [WIFI][APlistAdd] add SSID: ********
Connecting to wifi[ 2769][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 1 - SCAN_DONE
[ 2770][I][WiFiMulti.cpp:114] run(): [WIFI] scan done
[ 2770][I][WiFiMulti.cpp:119] run(): [WIFI] 10 networks found
[ 2799][D][WiFiMulti.cpp:149] run(): ---> 3: [6][**:**:**:**:**:**] ******** (-58) *
[ 2855][I][WiFiMulti.cpp:160] run(): [WIFI] Connecting BSSID: **:**:**:**:**:** SSID: ******** Channel: 6 (-58)
[ 3032][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 4 - STA_CONNECTED
[ 3555][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 7 - STA_GOT_IP
[ 3555][D][WiFiGeneric.cpp:880] _eventCallback(): STA IP: 192.168.86.137, MASK: 255.255.255.0, GW: 192.168.86.1
[ 3563][I][WiFiMulti.cpp:174] run(): [WIFI] Connecting done.
[ 3566][D][WiFiMulti.cpp:175] run(): [WIFI] SSID: ********
[ 3572][D][WiFiMulti.cpp:176] run(): [WIFI] IP: 192.168.86.137
[ 3578][D][WiFiMulti.cpp:177] run(): [WIFI] MAC: **:**:**:**:**:**
[ 3584][D][WiFiMulti.cpp:178] run(): [WIFI] Channel: 6
Syncing time........................................
Synchronized time: Thu Jan 1 00:00:23 1970
[ 23601][D][HTTPClient.cpp:298] beginInternal(): protocol: https, host: europe-west1-1.gcp.cloud2.influxdata.com port: 443 url: /health
[ 23605][D][HTTPClient.cpp:595] sendRequest(): request type: 'GET' redirCount: 0
[ 24720][D][HTTPClient.cpp:1141] connect(): connected to europe-west1-1.gcp.cloud2.influxdata.com:443
[ 24758][D][HTTPClient.cpp:1275] handleHeaderResponse(): code: 200
[ 24758][D][HTTPClient.cpp:1278] handleHeaderResponse(): size: 1224
[ 24759][D][HTTPClient.cpp:619] sendRequest(): sendRequest code=200
[ 24765][D][HTTPClient.cpp:383] disconnect(): still data in buffer (1224), clean up.
[ 24778][D][HTTPClient.cpp:392] disconnect(): tcp stop
Connected to InfluxDB: https://europe-west1-1.gcp.cloud2.influxdata.com
Writing: wifi_status,device=ESP32,SSID=******** rssi=-57i
[ 24790][D][HTTPClient.cpp:298] beginInternal(): protocol: https, host: europe-west1-1.gcp.cloud2.influxdata.com port: 443 url: /api/v2/write?org=****************&bucket=TEST
[ 24805][D][HTTPClient.cpp:595] sendRequest(): request type: 'POST' redirCount: 0
[ 24910][E][WiFiClientSecure.cpp:135] connect(): start_ssl_client: -1
[ 24912][D][HTTPClient.cpp:1134] connect(): failed connect to europe-west1-1.gcp.cloud2.influxdata.com:443
[ 24915][W][HTTPClient.cpp:1437] returnError(): error(-1): connection refused
[ 24921][D][HTTPClient.cpp:405] disconnect(): tcp is closed
Wait 10s
madlan
March 21, 2022, 2:37pm
6
Here’s the connection attempt with Verbose:
Syncing time.
Synchronized time: Mon Mar 21 14:33:49 2022
[ 3327][V][HTTPClient.cpp:247] beginInternal(): url: https://europe-west1-1.gcp.cloud2.influxdata.com/health
[ 3329][D][HTTPClient.cpp:298] beginInternal(): protocol: https, host: europe-west1-1.gcp.cloud2.influxdata.com port: 443 url: /health
[ 3341][D][HTTPClient.cpp:595] sendRequest(): request type: 'GET' redirCount: 0
[ 3348][V][ssl_client.cpp:61] start_ssl_client(): Free internal heap before TLS 261636
[ 3356][V][ssl_client.cpp:67] start_ssl_client(): Starting socket
[ 3428][V][ssl_client.cpp:143] start_ssl_client(): Seeding the random number generator
[ 3429][V][ssl_client.cpp:152] start_ssl_client(): Setting up the SSL/TLS structure...
[ 3433][V][ssl_client.cpp:175] start_ssl_client(): Loading CA cert
[ 3504][V][ssl_client.cpp:244] start_ssl_client(): Setting hostname for TLS session...
[ 3504][V][ssl_client.cpp:259] start_ssl_client(): Performing the SSL/TLS handshake...
[ 4510][V][ssl_client.cpp:280] start_ssl_client(): Verifying peer X.509 certificate...
[ 4511][V][ssl_client.cpp:288] start_ssl_client(): Certificate verified.
[ 4514][V][ssl_client.cpp:303] start_ssl_client(): Free internal heap after TLS 218320
[ 4521][D][HTTPClient.cpp:1141] connect(): connected to europe-west1-1.gcp.cloud2.influxdata.com:443
[ 4531][V][ssl_client.cpp:351] send_ssl_data(): Writing HTTP request with 311 bytes...
[ 4584][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'HTTP/1.1 200 OK'
[ 4585][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'Date: Mon, 21 Mar 2022 14:33:51 GMT'
[ 4589][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'Content-Type: text/html'
[ 4597][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'Content-Length: 1224'
[ 4604][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'Connection: close'
[ 4611][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'last-modified: Mon, 21 Mar 2022 08:32:04 GMT'
[ 4621][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'vary: Accept-Encoding'
[ 4628][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'etag: "62383804-4c8"'
[ 4636][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'accept-ranges: bytes'
[ 4643][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'Strict-Transport-Security: max-age=15724800; includeSubDomains'
[ 4654][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'X-Influxdb-Request-ID: 36265316492e872102de912d6d2cb790'
[ 4664][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: 'X-Influxdb-Build: Cloud'
[ 4672][V][HTTPClient.cpp:1234] handleHeaderResponse(): RX: ''
[ 4678][D][HTTPClient.cpp:1275] handleHeaderResponse(): code: 200
[ 4683][D][HTTPClient.cpp:1278] handleHeaderResponse(): size: 1224
[ 4689][D][HTTPClient.cpp:619] sendRequest(): sendRequest code=200
[ 4696][D][HTTPClient.cpp:383] disconnect(): still data in buffer (1224), clean up.
[ 4709][V][ssl_client.cpp:311] stop_ssl_socket(): Cleaning SSL connection.
[ 4710][D][HTTPClient.cpp:392] disconnect(): tcp stop
[ 4715][V][ssl_client.cpp:311] stop_ssl_socket(): Cleaning SSL connection.
Writing: wifi_status,device=ESP32,SSID=********rssi=-56i
[ 4734][V][HTTPClient.cpp:247] beginInternal(): url: https://europe-west1-1.gcp.cloud2.influxdata.com/api/v2/write?org=********&bucket=TEST
[ 4746][D][HTTPClient.cpp:298] beginInternal(): protocol: https, host: europe-west1-1.gcp.cloud2.influxdata.com port: 443 url: /api/v2/write?org=********&bucket=TEST
[ 4762][D][HTTPClient.cpp:595] sendRequest(): request type: 'POST' redirCount: 0
[ 4769][V][ssl_client.cpp:61] start_ssl_client(): Free internal heap before TLS 261000
[ 4777][V][ssl_client.cpp:67] start_ssl_client(): Starting socket
[ 4814][V][ssl_client.cpp:143] start_ssl_client(): Seeding the random number generator
[ 4815][V][ssl_client.cpp:152] start_ssl_client(): Setting up the SSL/TLS structure...
[ 4818][V][ssl_client.cpp:175] start_ssl_client(): Loading CA cert
[ 4889][V][ssl_client.cpp:244] start_ssl_client(): Setting hostname for TLS session...
[ 4890][V][ssl_client.cpp:259] start_ssl_client(): Performing the SSL/TLS handshake...
[ 4897][E][WiFiClientSecure.cpp:135] connect(): start_ssl_client: -1
[ 4901][V][ssl_client.cpp:311] stop_ssl_socket(): Cleaning SSL connection.
[ 4907][D][HTTPClient.cpp:1134] connect(): failed connect to europe-west1-1.gcp.cloud2.influxdata.com:443
[ 4916][W][HTTPClient.cpp:1437] returnError(): error(-1): connection refused
[ 4923][D][HTTPClient.cpp:405] disconnect(): tcp is closed
Wait 10s
ESP32 Arduino Core 2.0.2 has an issue with repeated TLS connection. This issue is already fixed in the master.
You can either downgrade ESP32 Arduino Core to 2.0.1 or apply the fix in your environment by simply copying the fixed file:
Download ssl_client.cpp
Find location of the ESP32 Arduino Core libraries folder on your system. On Windows it is: C:\Users\<your-user-name>\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2\Libraries
Copy downloaded ssl_client.cpp to the libraries\WiFiClientSecure\src\ssl_client.cpp
Rebuild the sketch
madlan
March 23, 2022, 1:12pm
8
Great - works perfectly with the latest master.
