I need some help:
I’ve two databases, containing the same data.
Now I want to INTEGRATE the old into the new one.
The old one is about 6months old
How can I do this?
Kind regards
Christoph Horschler
I need some help:
How can I do this?
Kind regards
Christoph Horschler
@Horschie
You can use the INTO clause :
SELECT * INTO "your_new_database"."autogen".:MEASUREMENT FROM "your_old_database"."autogen"./.*/ GROUP BY *
Ok, sorry.
I fehlt to Seite, that the Databases are on different hosts…
Kind regards
