EDIT: nvm, merged using influx_inspect, curl and plain text files
First of all thanks for InfluxDB, looks promising.
Unfortunately kinda lost here.
Is it possible to merge database 2) and 3) into 1) ?
Played with SELECT INTO and backrefs but i think options are limited (hope i’m wrong)
pi_sensors
A fresh one, updated since the last 3 days.SHOW MEASUREMENTS: name ---- pi_sensors SHOW SERIES: key --- pi_sensors,device=rpiB pi_sensors,device=rpiK pi_sensors,device=rpiP SHOW FIELD KEYS: fieldKey fieldType -------- --------- battery integer humidity integer pressure integer temperature integer -
rpi11 (merge into pi_sensors as device=rpiB)
Historical data, last 2 years from RRDSHOW MEASUREMENTS: name ---- meas_data SHOW SERIES: key --- meas_data SHOW FIELD KEYS: fieldKey fieldType -------- --------- battery integer temperature integer -
rpiLDO (merge into pi_sensors as device=rpiK)
Historical data, last 2 years from RRDSHOW MEASUREMENTS: name ---- meas_data SHOW SERIES: key --- meas_data SHOW FIELD KEYS: fieldKey fieldType -------- --------- battery integer temperature integer pressure integer
Thanks,
Bart
