I have two Backups of the same Database (influx : version 1.6.7~rc0)
1 is from Feb2023 until 13. August 2023. I have a Backup made with: "influxd backup -portable -database Datenbank1 /backup"
Then my system broke and instead of restoring it i made a new infux installation with the same values. So my second Backup and the running system is from 14. August 2023 until now.
How can I merge the Data from the old Backup into my new Database? The content ist the same, but with different Timestamps…
One way to handle this would be to restore the backup to a temporary instance. Then you can use the influx_inspect utility to export the desired data from the old backup. Once you’ve exported it, you can write it back into your new database.
