How can we setup or configure Influxdb with chronograph.? Please explain step by step if possible.
Did you RTM? It is pretty straight forward.
Installing InfluxDB:
Installing Chronograf and configuring it with InfluxDB
There is a pretty decent how to guide here
The versions used are a little out dated now, you should replace the links in the commands to use the more recent releases of the TICK stack but that guide is good.
It’s what i used to get the whole stack working in the first place.
That’s a good link too. I do wish Influx had more “tutorials” that go end to end with basic configuration to get running
Agreed, it would be nice to see some real world examples/tutorials as opposed to an overview and vague explanation.
I’m not really a developer so sitting and reading through the docs at first was a bit much to take in, personally i learn by being shown or through examples.
can you please tell me what will be “–web.listen-address” for influxDB. i am using this in procfile.
This should be the IP Address/Hostname for the device InfluxDB/Chronograf is running on.
