I don’t quite understand what’s happening here…because the UI is reachable for a while (until the CMD closes), but I can’t seem to get it to fully start. Windows Server 16
C:\Program Files\InfluxData\influxdb>influxd
2023-07-03T18:54:15.174196Z info Welcome to InfluxDB {"log_id": "0ioHXWXW000", "version": "v2.7.0", "commit": "85f725f8b9", "build_date": "2023-04-05T15:32:38Z", "log_level": "info"}
2023-07-03T18:54:18.764230Z info Resources opened {"log_id": "0ioHXWXW000", "service": "bolt", "path": "C:\\Users\\Administrator\\.influxdbv2\\influxd.bolt"}
2023-07-03T18:54:18.776672Z info Resources opened {"log_id": "0ioHXWXW000", "service": "sqlite", "path": "C:\\Users\\Administrator\\.influxdbv2\\influxd.sqlite"}
2023-07-03T18:54:18.844024Z info Checking InfluxDB metadata for prior version. {"log_id": "0ioHXWXW000", "bolt_path": "C:\\Users\\Administrator\\.influxdbv2\\influxd.bolt"}
2023-07-03T18:54:18.845026Z info Using data dir {"log_id": "0ioHXWXW000", "service": "storage-engine", "service": "store", "path": "C:\\Users\\Administrator\\.influxdbv2\\engine\\data"}
2023-07-03T18:54:18.845026Z info Compaction settings {"log_id": "0ioHXWXW000", "service": "storage-engine", "service": "store", "max_concurrent_compactions": 4, "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
2023-07-03T18:54:18.846029Z info Open store (start) {"log_id": "0ioHXWXW000", "service": "storage-engine", "service": "store", "op_name": "tsdb_open", "op_event": "start"}
2023-07-03T18:54:18.861068Z info index opened with 8 partitions {"log_id": "0ioHXWXW000", "service": "storage-engine", "index": "tsi"}
2023-07-03T18:54:18.863096Z info loading changes (start) {"log_id": "0ioHXWXW000", "service": "storage-engine", "engine": "tsm1", "op_name": "field indices", "op_event": "start"}
2023-07-03T18:54:18.863096Z info loading changes (end) {"log_id": "0ioHXWXW000", "service": "storage-engine", "engine": "tsm1", "op_name": "field indices", "op_event": "end", "op_elapsed": "0.000ms"}
2023-07-03T18:54:18.864076Z info Opened file {"log_id": "0ioHXWXW000", "service": "storage-engine", "engine": "tsm1", "service": "filestore", "path": "C:\\Users\\Administrator\\.influxdbv2\\engine\\data\\5b744f167abf38a1\\autogen\\1916\\000000001-000000001.tsm", "id": 0, "duration": "0.000ms"}
2023-07-03T18:54:18.865078Z info Opened shard {"log_id": "0ioHXWXW000", "service": "storage-engine", "service": "store", "op_name": "tsdb_open", "index_version": "tsi1", "path": "C:\\Users\\Administrator\\.influxdbv2\\engine\\data\\5b744f167abf38a1\\autogen\\1916", "duration": "10.026ms"}
2023-07-03T18:54:18.865078Z info Open store (end) {"log_id": "0ioHXWXW000", "service": "storage-engine", "service": "store", "op_name": "tsdb_open", "op_event": "end", "op_elapsed": "19.050ms"}
2023-07-03T18:54:18.866081Z info Starting retention policy enforcement service {"log_id": "0ioHXWXW000", "service": "retention", "check_interval": "30m"}
2023-07-03T18:54:18.866081Z info Starting precreation service {"log_id": "0ioHXWXW000", "service": "shard-precreation", "check_interval": "10m", "advance_period": "30m"}
2023-07-03T18:54:18.868086Z info Starting query controller {"log_id": "0ioHXWXW000", "service": "storage-reads", "concurrency_quota": 1024, "initial_memory_bytes_quota_per_query": 9223372036854775807, "memory_bytes_quota_per_query": 9223372036854775807, "max_memory_bytes": 0, "queue_size": 1024}
2023-07-03T18:54:18.872097Z info Configuring InfluxQL statement executor (zeros indicate unlimited). {"log_id": "0ioHXWXW000", "max_select_point": 0, "max_select_series": 0, "max_select_buckets": 0}
2023-07-03T18:54:18.958017Z info Starting {"log_id": "0ioHXWXW000", "service": "telemetry", "interval": "8h"}
2023-07-03T18:54:18.962031Z info Listening {"log_id": "0ioHXWXW000", "service": "tcp-listener", "transport": "http", "addr": ":8086", "port": 8086}
