i’m completly new to Influx and maybe this is easly fixed.
I set up a Influxdb and configured it manly through the web inteface. If i just run influxd it runs perfect withouth Problems. But if i want to start the Influx service job it just not start.
System Information:
Ubuntu 20.04.4 LTS
InfluxDB v2.7.10
journalctl:
-- Logs begin at Fri 2024-10-04 13:48:33 UTC, end at Tue 2024-10-15 09:25:14 UTC. --
Oct 14 07:19:37 monitoringsrv1 systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.831418Z lvl=info msg="InfluxDB starting" log_id=0sEUBvPl000 version=1.8.10 branch=1.8 commit=688e697c51fd
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.831443Z lvl=info msg="Go runtime" log_id=0sEUBvPl000 version=go1.13.8 maxprocs=4
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2017]: time="2024-10-14T07:19:37Z" level=warning msg="DBUS_SESSION_BUS_ADDRESS envvar looks to be not set, this can lead to runaway dbus-daemon processes. To avoid this, set envvar DBUS_SESSION_BUS_ADDRESS=$XDG_RUNTIME_DIR/bus (if it exists) or DBUS_SESSION_BU>
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2017]: Error: unknown command "config" for "influxd"
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2017]: See 'influxd -h' for help
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2036]: time="2024-10-14T07:19:37Z" level=warning msg="DBUS_SESSION_BUS_ADDRESS envvar looks to be not set, this can lead to runaway dbus-daemon processes. To avoid this, set envvar DBUS_SESSION_BUS_ADDRESS=$XDG_RUNTIME_DIR/bus (if it exists) or DBUS_SESSION_BU>
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2036]: Error: unknown command "config" for "influxd"
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2036]: See 'influxd -h' for help
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934123Z lvl=info msg="Using data dir" log_id=0sEUBvPl000 service=store path=/var/lib/influxdb/data
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934176Z lvl=info msg="Compaction settings" log_id=0sEUBvPl000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934187Z lvl=info msg="Open store (start)" log_id=0sEUBvPl000 service=store trace_id=0sEUBvoW000 op_name=tsdb_open op_event=start
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934210Z lvl=info msg="Open store (end)" log_id=0sEUBvPl000 service=store trace_id=0sEUBvoW000 op_name=tsdb_open op_event=end op_elapsed=0.024ms
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934230Z lvl=info msg="Opened service" log_id=0sEUBvPl000 service=subscriber
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934234Z lvl=info msg="Starting monitor service" log_id=0sEUBvPl000 service=monitor
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934237Z lvl=info msg="Registered diagnostics client" log_id=0sEUBvPl000 service=monitor name=build
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934240Z lvl=info msg="Registered diagnostics client" log_id=0sEUBvPl000 service=monitor name=runtime
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934243Z lvl=info msg="Registered diagnostics client" log_id=0sEUBvPl000 service=monitor name=network
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934247Z lvl=info msg="Registered diagnostics client" log_id=0sEUBvPl000 service=monitor name=system
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934257Z lvl=info msg="Starting precreation service" log_id=0sEUBvPl000 service=shard-precreation check_interval=10m advance_period=30m
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934263Z lvl=info msg="Starting snapshot service" log_id=0sEUBvPl000 service=snapshot
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934266Z lvl=info msg="Starting continuous query service" log_id=0sEUBvPl000 service=continuous_querier
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934330Z lvl=info msg="Starting HTTP service" log_id=0sEUBvPl000 service=httpd authentication=false
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934336Z lvl=info msg="opened HTTP access log" log_id=0sEUBvPl000 service=httpd path=stderr
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934643Z lvl=info msg="Listening on HTTP" log_id=0sEUBvPl000 service=httpd addr=[::]:8086 https=false
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934655Z lvl=info msg="Starting retention policy enforcement service" log_id=0sEUBvPl000 service=retention check_interval=30m
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934661Z lvl=info msg="Storing statistics" log_id=0sEUBvPl000 service=monitor db_instance=_internal db_rp=monitor interval=10s
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934773Z lvl=info msg="Sending usage statistics to usage.influxdata.com" log_id=0sEUBvPl000
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2015]: ts=2024-10-14T07:19:37.934943Z lvl=info msg="Listening for signals" log_id=0sEUBvPl000
Oct 14 07:19:37 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 1 attempts...
Oct 14 07:19:38 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 2 attempts...
Oct 14 07:19:39 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 3 attempts...
Oct 14 07:19:41 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 4 attempts...
Oct 14 07:19:42 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 5 attempts...
Oct 14 07:19:43 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 6 attempts...
Oct 14 07:19:44 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 7 attempts...
Oct 14 07:19:45 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 8 attempts...
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 9 attempts...
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0afed58-89fc-11ef-8001-005056ac6803 186
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0affdea-89fc-11ef-8002-005056ac6803 176
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b22fd4-89fc-11ef-8003-005056ac6803 70
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b29e37-89fc-11ef-8004-005056ac6803 66
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b40619-89fc-11ef-8005-005056ac6803 26
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b40896-89fc-11ef-8006-005056ac6803 17
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b5b7cf-89fc-11ef-8007-005056ac6803 25
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b5ef91-89fc-11ef-8008-005056ac6803 56
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b78d83-89fc-11ef-8009-005056ac6803 27
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b803bc-89fc-11ef-800a-005056ac6803 31
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b90bd9-89fc-11ef-800b-005056ac6803 28
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0b9c8a4-89fc-11ef-800c-005056ac6803 34
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0babb79-89fc-11ef-800d-005056ac6803 60
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0bba2fb-89fc-11ef-800e-005056ac6803 35
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0bd955d-89fc-11ef-800f-005056ac6803 34
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0bd9875-89fc-11ef-8010-005056ac6803 19
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0bf2b98-89fc-11ef-8011-005056ac6803 58
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0bf750b-89fc-11ef-8012-005056ac6803 36
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0c116cb-89fc-11ef-8013-005056ac6803 30
Oct 14 07:19:46 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.0.32.13 - - [14/Oct/2024:07:19:46 +0000] "POST /api/v2/write?bucket=IT+Monitoring&org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 404 50 "-" "Telegraf/1.32.1 Go/1.23.1" b0c14317-89fc-11ef-8014-005056ac6803 24
Oct 14 07:19:47 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 10 attempts...
Oct 14 07:19:48 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 11 attempts...
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b26fa2a4-89fc-11ef-8015-005056ac6803 64
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2719956-89fc-11ef-8016-005056ac6803 16
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b271f137-89fc-11ef-8017-005056ac6803 13
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b272caee-89fc-11ef-8018-005056ac6803 18
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2007]: InfluxDB API unavailable after 12 attempts...
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b27a7a84-89fc-11ef-8019-005056ac6803 28
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b27ec6a2-89fc-11ef-801a-005056ac6803 24
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b27efff9-89fc-11ef-801b-005056ac6803 30
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2801fdc-89fc-11ef-801c-005056ac6803 12
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b281c374-89fc-11ef-801d-005056ac6803 14
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b28645ae-89fc-11ef-801e-005056ac6803 17
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b288f61b-89fc-11ef-801f-005056ac6803 19
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b28b86b0-89fc-11ef-8020-005056ac6803 16
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b28cf7a2-89fc-11ef-8021-005056ac6803 17
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b290ed68-89fc-11ef-8022-005056ac6803 15
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b291f276-89fc-11ef-8023-005056ac6803 36
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2a72291-89fc-11ef-8024-005056ac6803 31
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2a78496-89fc-11ef-8025-005056ac6803 13
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2afbf99-89fc-11ef-8026-005056ac6803 34
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2b015ce-89fc-11ef-8027-005056ac6803 46
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2b03c03-89fc-11ef-8028-005056ac6803 12
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2b1413d-89fc-11ef-8029-005056ac6803 15
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2b1470a-89fc-11ef-802a-005056ac6803 16
Oct 14 07:19:49 monitoringsrv1 influxd-systemd-start.sh[2015]: [httpd] 10.1.164.47 - - [14/Oct/2024:07:19:49 +0000] "POST /api/v2/query?org=GEWO+Feinmechanik+GmbH HTTP/1.1 " 403 100 "-" "influxdb-client-go/2.13.0 (linux; arm)" b2b18a9d-89fc-11ef-802b-005056ac6803 14
