few weeks ago I installed influxDB thru homebrew. (v2.x)
It was working fine. But, today my MBP suddenly crashed and restarted. After this, i tried to start influx from terminal (“influxd”) but following error occured.
I even uninstalled, removed the files in usr/local/etc/influxdb2 (uninstalled the influx-cli also) and re-installed it.
Nothing changed. Same error.
Help please.
Thanks. alptekin
❯ influxd
2023-07-21T13:41:17.712105Z info Welcome to InfluxDB {“log_id”: “0jAAmJ2l000”, “version”: “2.7.1”, “commit”: “407fa622e9”, “build_date”: “2023-04-27T19:36:53Z”, “log_level”: “info”}
2023-07-21T13:41:17.759735Z info Resources opened {“log_id”: “0jAAmJ2l000”, “service”: “bolt”, “path”: “/Users/alptekin/.influxdbv2/influxd.bolt”}
2023-07-21T13:41:17.760589Z info Resources opened {“log_id”: “0jAAmJ2l000”, “service”: “sqlite”, “path”: “/Users/alptekin/.influxdbv2/influxd.sqlite”}
2023-07-21T13:41:17.893065Z info Checking InfluxDB metadata for prior version. {“log_id”: “0jAAmJ2l000”, “bolt_path”: “/Users/alptekin/.influxdbv2/influxd.bolt”}
2023-07-21T13:41:17.894553Z info Using data dir {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “service”: “store”, “path”: “/Users/alptekin/.influxdbv2/engine/data”}
2023-07-21T13:41:17.894628Z info Compaction settings {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “service”: “store”, “max_concurrent_compactions”: 4, “throughput_bytes_per_second”: 50331648, “throughput_bytes_per_second_burst”: 50331648}
2023-07-21T13:41:17.894639Z info Open store (start) {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “service”: “store”, “op_name”: “tsdb_open”, “op_event”: “start”}
2023-07-21T13:41:17.920409Z info index opened with 8 partitions {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “index”: “tsi”}
2023-07-21T13:41:17.920774Z info index opened with 8 partitions {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “index”: “tsi”}
2023-07-21T13:41:17.924229Z info loading changes (start) {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “op_name”: “field indices”, “op_event”: “start”}
2023-07-21T13:41:17.924234Z info loading changes (start) {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “op_name”: “field indices”, “op_event”: “start”}
2023-07-21T13:41:17.924300Z info loading changes (end) {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “op_name”: “field indices”, “op_event”: “end”, “op_elapsed”: “0.077ms”}
2023-07-21T13:41:17.924298Z info loading changes (end) {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “op_name”: “field indices”, “op_event”: “end”, “op_elapsed”: “0.067ms”}
2023-07-21T13:41:17.928822Z info Opened file {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “service”: “filestore”, “path”: “/Users/alptekin/.influxdbv2/engine/data/8cb196bcb87c5519/autogen/5/000000003-000000001.tsm”, “id”: 1, “duration”: “2.132ms”}
2023-07-21T13:41:17.928819Z info Opened file {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “service”: “filestore”, “path”: “/Users/alptekin/.influxdbv2/engine/data/8cb196bcb87c5519/autogen/5/000000004-000000001.tsm”, “id”: 2, “duration”: “2.127ms”}
2023-07-21T13:41:17.928819Z info Opened file {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “service”: “filestore”, “path”: “/Users/alptekin/.influxdbv2/engine/data/8cb196bcb87c5519/autogen/6/000000002-000000001.tsm”, “id”: 1, “duration”: “2.169ms”}
2023-07-21T13:41:17.928807Z info Opened file {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “service”: “filestore”, “path”: “/Users/alptekin/.influxdbv2/engine/data/8cb196bcb87c5519/autogen/6/000000001-000000001.tsm”, “id”: 0, “duration”: “2.154ms”}
2023-07-21T13:41:17.928881Z info Opened file {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “engine”: “tsm1”, “service”: “filestore”, “path”: “/Users/alptekin/.influxdbv2/engine/data/8cb196bcb87c5519/autogen/5/000000002-000000003.tsm”, “id”: 0, “duration”: “2.221ms”}
2023-07-21T13:41:17.930862Z info Opened shard {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “service”: “store”, “op_name”: “tsdb_open”, “index_version”: “tsi1”, “path”: “/Users/alptekin/.influxdbv2/engine/data/8cb196bcb87c5519/autogen/5”, “duration”: “28.554ms”}
2023-07-21T13:41:17.930966Z info Opened shard {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “service”: “store”, “op_name”: “tsdb_open”, “index_version”: “tsi1”, “path”: “/Users/alptekin/.influxdbv2/engine/data/8cb196bcb87c5519/autogen/6”, “duration”: “28.703ms”}
2023-07-21T13:41:17.931029Z info Open store (end) {“log_id”: “0jAAmJ2l000”, “service”: “storage-engine”, “service”: “store”, “op_name”: “tsdb_open”, “op_event”: “end”, “op_elapsed”: “36.392ms”}
2023-07-21T13:41:17.931054Z info Starting retention policy enforcement service {“log_id”: “0jAAmJ2l000”, “service”: “retention”, “check_interval”: “30m”}
2023-07-21T13:41:17.931068Z info Starting precreation service {“log_id”: “0jAAmJ2l000”, “service”: “shard-precreation”, “check_interval”: “10m”, “advance_period”: “30m”}
2023-07-21T13:41:17.935916Z info Starting query controller {“log_id”: “0jAAmJ2l000”, “service”: “storage-reads”, “concurrency_quota”: 1024, “initial_memory_bytes_quota_per_query”: 9223372036854775807, “memory_bytes_quota_per_query”: 9223372036854775807, “max_memory_bytes”: 0, “queue_size”: 1024}
2023-07-21T13:41:17.942977Z info Configuring InfluxQL statement executor (zeros indicate unlimited). {“log_id”: “0jAAmJ2l000”, “max_select_point”: 0, “max_select_series”: 0, “max_select_buckets”: 0}
2023-07-21T13:41:18.100527Z info Starting {“log_id”: “0jAAmJ2l000”, “service”: “telemetry”, “interval”: “8h”}
2023-07-21T13:41:18.100784Z info Listening {“log_id”: “0jAAmJ2l000”, “service”: “tcp-listener”, “transport”: “http”, “addr”: “:8086”, “port”: 8086}
2023-07-21T13:41:28.011854Z error Unable to write gathered points {“log_id”: “0jAAmJ2l000”, “service”: “scraper”, “scraper-name”: “new target”, “error”: “database not found: ff285bba95c2213e”}
2023-07-21T13:41:38.003893Z error Unable to write gathered points {“log_id”: “0jAAmJ2l000”, “service”: “scraper”, “scraper-name”: “new target”, “error”: “database not found: ff285bba95c2213e”}
