Influx TSM - Migration 30 to 40 TB of Data
Hi there!
We are currently using an InfluxDB 2.x Cloud TSM instance on AWS.
Now, our customer wants to migrate the InfluxDB 2.x from one server to another as a same InfluxDB 2.x. The total data could be around 30 to 40 TB.
For that I have done a lot of research on that, but end up in some of the following options
  1. Influx backup and restore - Which only have the option to backup and restore the entire data, which is practically not possible for the data we have.
  2. Influx Telegraf - Which one the wonderful tools in InfluxDB, but it does not have an Input Plugin for its own InfluxDB. It has only the output plugin.
  3. Influx query and write - Which is the option currently we have in our hands - as it supports to write across server, ORG and etc. But the cons are it is much slower and the files or .lp format is much larger than the actual data - which forces us to increase the infra we have.
  4. Influxd inspect backup -lp - same as the Influx query and write.
If you have any solution for the above scenario kindly update them ASAP.
Any help is appreciated, thanks!
Those are valid conclusions.
