Hi guys !
why i have 27 databases under /var/lib/influx
but when i set ''influx=>show databases ‘’ i see only 14 databases ??
Hello @Annonyme1,
Is there any pattern you’re noticing with the databases that aren’t showing? Are they all older databases? Did you upgrade recently? If you create a new database, can you see it with the show databases command? Can you please share the two lists? And finally, a silly question, but did you scroll down? Thank you.
