Last update broke my InfluxDB
Hi!
Running InfluxDB on Ubuntu 22.04, a few weeks ago I did some updates (to 2.4 I believe?) and after restart, my influxDB didn’t recognize me anymore and my programs (namely Home Assistant) were complaining about not having permission to access the InfluxDB database anymore
I had to redo the setup, i.e. buckets, tokens and even login information.
Just wondering if this has been reported before and can I still access my old database?
Hello @Antonio,
Welcome!
That’s cool to see you’re doing some home automation!
Hmm I haven’t seen that before. Can you share the error? How did you perform the updates?
Hello!
Sorry, I don;t have any error logs.
The update was just the regular way, where I performed all system updates
sudo apt-get update
sudo apt-get upgrade
via terminal line
InfluxDB is part of my list of checking for for system updates
I don’t think my old database was deleted, though, or how I can know or check that?
thanks
I have the same issue. Has this been resolved?
