Hi!
On Influx CLI 2.0.7 it’s not possible to open the influx cli, when typing ‘influx’ you receive the same as ‘influx -h’. I read, this comfortable feature was removed on version 2.+ . Instead we should use flux repl.
I read a while but I stuck - you find many examples about flux repl, but how can I query the DB to create a database with flux repl?
Thanks!
@wolfbiker1 the flux repl (and flux in general, as far as I know) doesn’t support creating buckets, it can only query data from existing buckets. The influx CLI has a bucket command that you can use to create your buckets (docs here). It also has a query command that you can use for non-interactive flux queries (docs here). If you need the REPL experience, you’ll either need to bounce between the two CLIs or use the script editor in the UI.
Hey dan, thanks, that did the trick!
