how to create kapacitor.conf file in influxdb2.1 i am unable to create it
Hello @Tayyab_Zamir,
Welcome have you seen this documentation:
@Tayyab_Zamir,
May I ask though, what are you trying to do with Kapacitor. Maybe we can just do it with Flux and tasks instead since you’re using 2.1??
can kapacitor is used for machine leaning prediction i am using influx 2.1
@Tayyab_Zamir,
What type of forecasting algorithm are you using?
Yes you could use kapacitor and create a UDF Write socket-based user-defined functions (UDFs) | Kapacitor 1.6 Documentation
However you might also want to look into using flux with lambda and implementing your forecasting that way.
