I need to use HTTPS to send data into InfluxDB. I have created an SSL cert in PEM format, and it works fine. But I had to create the PEM without a password, because I couldn’t find any way in the InfluxDB config files to specify the password. Is there a way to have a password for the PEM?
Related topics
Topic | Replies | Views | Activity | |
Issue when enable https with influxDB | 4 | 4474 | July 23, 2018 | |
SOLVED: Write data to InfluxDB with ESP / ESP8266 over Internet & HTTPS using letsencrypt / certbot | 1 | 1183 | January 25, 2021 | |
InfluxDB 2 Config file + SSL | 14 | 7598 | February 14, 2024 | |
How to use https with influx api call? | 1 | 666 | September 15, 2020 | |
Security InfluxDB | 0 | 437 | December 9, 2019 |
