InfluxDB 2 Config file + SSL
I’m new to both InfluxDB and newish to Linux.
I’m trying to setup influxdb + telegraf (then Grafana). Now i’ve got the basics install, influxdb and telegraf and all is running and telegraf is sending data on the local machine.
Now i want to get influx+telegraf into SSL HTTPS. but having issues getting a config file setup and running.
If i manually run
influxd --tls-cert=“/etc/letsencrypt/live//fullchain.pem” --tls-key=“/etc/letsencrypt/live//privkey.pem”
that runs and i can get onto the web ui via https://:8086
I installed on CentOS8 via the RPM package so run via systemctl. How do i create a config file and add the SSL certificates to get it running under https?
I’ve tried creating a .yml file and setting the config file path
export INFLUXD_CONFIG_PATH=/etc/influxdb/influxdb.yml
But that doesn’t seem to do anything.
Also tried
influx config create --active -n config-name -u http://localhost:8086 -t mySuP3rS3cr3tT0keN -o example-org
but not sure where to edit and add the SSL stuff.
Hello @hobbit666,
Have you taken a look at:
Enable TLS/SSL encryption | InfluxDB OSS 2.0 Documentation?
Yeah I have and it works when I run that command.
But I’ve installed via RPM so it’s running as a service. So how do I get the SSL running with the service?
I’m think from the docs I need a configuration file but can’t seem to work out how.
You should already have a configuration file. But which config file are you referring to? What step are you stuck on?
Hi, @hobbit666 same problem here…
did you found a solution for your problem.
No kind of gave up for now and stuck to v1.
Might try it again soon
Same issue here. I can manually start influxd with the SSL parameters as mentioned in the docs, and it works. Influx also starts on reboot as I enabled it in systemctl but it does not start with SSL enabled. Not sure where to define that specifically.
you will find this article useful if you haven’t already fixed this:
basically you have the option to add lines to the config file ( /etc/influxdb/config.toml )
e.g - add this for the toml file:
tls-cert = "/path/to/influxdb.crt"
tls-key = "/path/to/influxdb.key"
or this for yaml:
tls-cert: /path/to/influxdb.crt
tls-key: /path/to/influxdb.key
or you can choose to add arguments to your service configuration file at:
/lib/systemd/system/influxdb.service (for centos)
you will find more info here:
Working with docker-compose, config.toml seems to have no effect on TLS.
Also, I can’t find any details about using docker environment variables for V2. INFLUXDB_HTTP_HTTPS_CERTIFICATE and INFLUXDB_HTTP_HTTPS_PRIVATE_KEY are working fine with influxdb 1.8.3 but not with 2.0.6…
Thx !
Some update about ssl in influx 2.0.6???
FROM influxdb:latest
LABEL description=“InfluxDB image” version=“1.0.0”
ENV DOCKER_INFLUXDB_INIT_MODE=setup
ENV DOCKER_INFLUXDB_INIT_USERNAME=user
ENV DOCKER_INFLUXDB_INIT_PASSWORD=pass
ENV DOCKER_INFLUXDB_INIT_ORG=org
ENV DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=tokn
ENV DOCKER_INFLUXDB_INIT_BUCKET=bucket
ENV DOCKER_INFLUXDB_INIT_RETENTION=365d
ENV INFLUXD_HTTP_BIND_ADDRESS=:8086
ENV INFLUXD_HTTP_IDLE_TIMEOUT=3m0s
ENV INFLUXD_HTTP_READ_HEADER_TIMEOUT=10s
ENV INFLUXD_HTTP_READ_TIMEOUT=15s
ENV INFLUXD_HTTP_WRITE_TIMEOUT=15s
ENV INFLUXD_LOG_LEVEL=info
ENV INFLUXD_QUERY_CONCURRENCY=20
ENV INFLUXD_SECRET_STORE=bolt
ENV INFLUXD_SESSION_LENGTH=60
ENV INFLUXD_BOLT_PATH=/var/lib/influxdb2/influxd.bolt
ENV INFLUXD_ENGINE_PATH=/var/lib/influxdb2/engine
ENV INFLUXD_TLS_CERT=…/cert.pem
ENV INFLUXD_TLS_KEY=…/key.pem
ENV INFLUXD_TLS_MIN_VERSION=1.2
ENV INFLUXD_TLS_STRICT_CIPHERS=true
ENV INFLUXD_TRACING_TYPE=log
EXPOSE 8086 8083 443
This is my dockerfile, SSL dont work, it execute this “lvl=info msg=Listening log_id=0U6evMlW000 service=tcp-listener transport=http addr=:9999 port=9999” and then go down
verify your config settings:
#influx config ls
Active Name URL Org
jozefina http://192.168.0.105:8086 influxdata
default https://ruth:8086 ooo
if not HTTPS in your URL you have to update that config record
i forgot to mention one more note: if you run once influx as root with influxd and then later set it as service with systemctl it is running under influxd user.
i cannot find the link now, but it was mention somewhere and i know i caused me problems
Check out the replies on this thread:
Good luck
I had the same problem.
If you run influxdb as a service (systemctl start influxdb) then it is started with “influxdb” user.
Solution was to change tls-cert and tls-key files ownership to influxdb user:
chown influxdb.influxdb <path-to-file.crt>
chown influxdb.influxdb <path-to-file.key>
In documentation (https://docs.influxdata.com/influxdb/v2/admin/security/enable-tls/) it’s not explicitly written, that you should also check for ownership of files.
I too had the same issue on a raspberry pi 4b with debian bookworm until I finally found the solution! As there were no automatic install options for this setup (arm64 .deb) I followed the official guidance for manual installation:
https://docs.influxdata.com/influxdb/v2/install/?t=Linux#manually-download-and-install-the-influxd-binary
I then created a “config.toml” file and added the TLS-paths as suggested by the official documentation. I also ensured the permissions were correct for the certificates (at least read rights for user influxdb). This still didn’t work so I tried all kinds of various suggestions available on the internet, still without luck.
In the end what worked for me was to first stop the influxdb.service via command:
sudo systemctl stop influxdb.service
and then add the TLS-commands (–tls-key --tls-cert) in the file influxd-systemd-start.sh
in my case it was located here: /usr/lib/influxdb/scripts/
I did this via command:
sudo nano /usr/lib/influxdb/scripts/influxd-systemd-start.sh
The resulting file looks like this (remember to change path to your cert/key files and ensure you have set the correct permissions)
#!/bin/bash -e
/usr/bin/influxd --reporting-disabled --tls-cert="/path/to/crtfile --tls-key="/path/to/keyfile" &
PID=$!
echo $PID > /var/lib/influxdb/influxd.pid
PROTOCOL="http"
BIND_ADDRESS=$(influxd print-config --key-name http-bind-address)
TLS_CERT=$(influxd print-config --key-name tls-cert | tr -d '"')
TLS_KEY=$(influxd print-config --key-name tls-key | tr -d '"')
if [ -n "${TLS_CERT}" ] && [ -n "${TLS_KEY}" ]; then
  echo "TLS cert and key found -- using https"
  PROTOCOL="https"
fi
HOST=${BIND_ADDRESS%:*}
HOST=${HOST:-"localhost"}
PORT=${BIND_ADDRESS##*:}
set +e
attempts=0
url="$PROTOCOL://$HOST:$PORT/ready"
result=$(curl -k -s -o /dev/null $url -w %{http_code})
while [ "${result:0:2}" != "20" ] && [ "${result:0:2}" != "40" ]; do
  attempts=$(($attempts+1))
  echo "InfluxDB API at $url unavailable after $attempts attempts..."
  sleep 1
done
echo "InfluxDB started"
set -e
After I had done that I was able to start the service again
sudo systemctl start influxdb.service
It does survive reboots (not sure about future updates though?). Hope that will help anyone out there :slight_smile:
