Hello everybody,
I’ve successfully installed InfluxDB 2.1.1 on Ubuntu 20.04, and I run it with no problem with HTTP. But now I need to use HTTPS. I followed the TLS configuration tutorial and I can run the influxd in HTTPS from command line specifying the .crt and .key files, but I don’t succeed in having the service systemd running in such a way that it gets the https configuration.
What should I look at?
Any idea of what I could be doing wrong?
How can I be sure, for instance, that the systemd is running influxd with the correct config file?
So many doubts…
Many thanks for your kind help
Nicola
