and i am able to connect through influxd cli command
./influx -ssl -host -unsafeSsl
Connected to https://:8086 version 1.4.2
InfluxDB shell version: 1.4.2
when i try the client certificate with the curl command, it always show error. when generated the client certificate, i already use -subj “/CN=admin” to specify the user in the client cert.
curl --cert client.pem --key client.key https://:8086/query --data-urlencode “q=SHOW DATABASES” -k{“error”:“unable to parse authentication credentials”}
would you please advise if i did anything wrong here?
I would try using the --cacert flag instead of the --cert flag as they have slightly different meanings to curl.
--cacert <CA certificate>
(SSL) Tells curl to use the specified certificate file to verify the peer. The file may contain
multiple CA certificates. The certificate(s) must be in PEM format. Normally curl is built to use
a default file for this, so this option is typically used to alter that default file.
curl recognizes the environment variable named 'CURL_CA_BUNDLE' if it is set, and uses the given
path as a path to a CA cert bundle. This option overrides that variable.
-E, --cert <certificate[:password]>
(SSL) Tells curl to use the specified client certificate file when getting a file with HTTPS, FTPS
or another SSL-based protocol. The certificate must be in PEM format. If the optional password
isn't specified, it will be queried for on the terminal. Note that this option assumes a
"certificate" file that is the private key and the private certificate concatenated! See --cert
and --key to specify them independently.
thanks David for your reply. i also tried with --cacert and it is the same result.
curl --cert client.pem --key client.key https://:8086/query --data-urlencode “q=SHOW DATABASES” --cacert ca.pem
do you have any working sample with self-signed cert?
I followed exactly the steps you did to create the certs, and to configure the InfluxDB server on localhost, but the curl command I ran – which succeeded – is:
It appears that the order of your parameters to curl were incorrect, and what I found was that the ‘q=SHOW DATABASES’ failed but ‘q=show databases’ worked.
I should point out that this will not work if auth_enabled=true as that will still require a username/password combination.
I am having basically the same problem and I find this answer confusing; the docs say that auth_enabled needs to be true for any authentication or authorization to happen at all, but you’re saying that auth_enabled needs to be false otherwise the server will use basic auth irrespective of whether or not there’s a client certificate being used for the connection? If so, how do I enforce authz when using client certs for authn?
