HTTP Notifications to Opsgenie
I am trying to to setup the HTTP notifications endpoint to send alerts to opsgenie, it tries to send with a “failed” status, is there anyway I can see the error code or payload?
I am using bearer as the Auth method with
URL: https://api.opsgenie.com/v2/alerts
Token: API key
Matthew
Does the request reach opsgenie or does it fail completely?
I’ve not tried with influxDB 2, but i have Kapacitor set up with influxdb 1.5 to forward alerts to the opsgenie API. They have an integration for it.
As i’m not sure how influx2 works, i don’t know if Kapacitor is part of it or if that has been replaced in influxDB2
I can see the notifications in the _monitoring database with _sent=false, and does not reach Opsgenie.
We have an influxdb 1.7 setup with Opsgenie and that works fine.
Influxdb 2.0 only has 3 available endpoints HTTP, Slack and PagerDuty.
Maybe it will require a dedicated Opsgenie endpoint as well?
