So updating and using InfluxDB 2.0 is quite the challenge, a beautiful interface but changed up quite a lot on config files. I know in Telegraf you have to do different settings such as Org, your token, bucket; is there something similar when editing the config files in Home Assistant? Following this tutorial all you really have to do is edit the configuration.yaml file in Home Assistant, but of course the instructions state for influxdb 1.x not 2.0. How would I do 2.0 config settings so I can pull the data?
Hello @FormBurden,
I’m sorry you’re having trouble. I’m not quite sure I’m not familiar with Home Assistant. This compatibility documentation might be useful to you though.
If you’re still having trouble please let me know and I’ll forward this question to someone who can help you better.
Hello @ingoratsdorf thank you for sharing your solution and welcome! What are you using home assistant with influxdb for? The documentation has certainly improved since then
