Hi all,
I’m new to the platform and I’ve been trying to connect my existing InfluxDB2.0 to Grafana, without succes!
Here is my configuration on Grafana:
Am I missing something? Hope someone can help… Thanks in advance
Those settings seem correct - I’m able to use similar ones on my machine to connect successfully.
Are you running grafana in a docker container by chance?
Hi, I’ve got it working. I removed the “/” from the URL and this seemed to work. Thank you for you help anyway.
