I want to export data from influx DB into a file and then load it back into another influx DB.
will influx_inspect export and influx -import would be a good idea? or should i do backup and restore.
if influx_inspect would be good then please also suggest from where can i get it installed on my machine.
i am using ubuntu.
Hi @neo1702 welcome ! ,
if you want to copy the complete DB , you can use backup /restore.
If it is only 1 measurement for example you can use the export / import.
influx_inspect should be present on your machine in the same directory as influx and influxd ,
do you find it ?
best regards
thanks for the response.
i want to get an entire DB exported.
i didn’t find influx_inspect in the directory that has influx and influxd.
also, when i type influxd --help it shows:
-config
-join
-pidfile
-cpuprofile
-memprofile
it does not show backup option.
