I’m testing for Influxdb2. I can see wal and data directories in /var/lib/influxdb/engine.
Do I need to point the wal and data directories to different disks to improve performance when using influxdb2, like for v1.x? The configuration file of influxdb2 only provides parameters for modifying the engine-path.
And, what factors influence the storage size of wal? How to estimate disk capacity for wal and data directories?
I’ve read the “Hardware sizing guidelines-> Bytes and compression” in docs for v1.8.
Can I assume the size of data directory can be calculated mainly based on points number, and wal directory is only related to write speed? In other words, the wal directory has nothing to do with the data volume of the data in the “data” directory, and the “old” data in the “wal” directory will be deleted naturally?
So, for a 4vCPU and 32GB memory instance, I can give wal a fixed small disk size, for example a 32GB disk and give a 4TB disk for data directory. Is this reasonable?
The doc also suggests to store wal and data on separate storage devices for heavy write load. Although I’m not facing this kind of scenario, I still want to know how to set separate wal and data paths on v2.x. Can you give me suggestions?
Hi Anaisdg, I’ve read this “InfluxDB file system layout” page. It mentioned “use the engine-path configuration option” to change engine directory, which is the parent directory of wal and data. This is why I said “The configuration file of influxdb2 only provides parameters for modifying the engine-path.”, wal and data is still on the same disk, and will not be separated.
I suspect that v2.x can not separate the wal directory and the data directory by configuration. Is the documentation incomplete, or does it not have the ability to do this?
