How to delete data (single series) from a database with endless retention policy?
I simply can’t delete any data.
Using delete from "%" where "entity_id"='entity_id=h5055_batt'; seems to work (no output, so it seems to fail silentsly), but doing a select shows/confirms: data still exists.
Retention policy is open end (Duration: ∞).
Using delete from "homeassistant"."autogen"."%" where "entity_id"='h5055_batt'; gives
ERR: error parsing query: retention policy not supported at line 1, char 1
:interrobang::interrobang::interrobang: HOW CAN I FREAKING GET RID OF DATA (single series) :interrobang::interrobang::interrobang:
@bcutter What version of InfluxDB are you using?
I am using what is provided by repository/influxdb at master · hassio-addons/repository · GitHub
This is solved in Delete data from DB with autogen retention policy - #7 by scott
