I’m collecting SNMP metrics from our router which are saved as incrementing octets (network traffic).
I have Grafana panel “Network Utilization per hour” which display as it says, bandwidth consumption per hour.
It’s hard to say exactly how you would write this query as I don’t know what your schema looks like. If your graphite names are your measurement name and the field name for the measurement is value, then I something like the following might work:
SELECT SUM(value * 60) FROM collectd.192.168.0.1.snmp.if_octets-ether1.tx WHERE time > now() - 6hr GROUP BY time(1h)
InfluxGraph can convert Graphite queries directly to Influx queries from a configurable schema optionally based on graphite templates as used by InfluxDB.
Eg, if your schema is:
measurement=snmp with tags ip=192.168.0.1, source=collectd, interface=if_octets-ether1,field=tx
Then a template:
source.ip.measurement.interface.field
will produce appropriate influx queries from the summarize(collectd.192.168.0.1.snmp.if_octets-ether1.tx <…>) and any other graphite queries. If not using any schema or templates no template configuration is needed.
