Thank you for watching my request!
Actually, i want to use snmp for monitoring existing bunch of devices.
So, it difficult to check each device’s ip, so i want to set agents ip by range. (ex> start to end)
is there anyway to do this?
No not directly within telegraf config. But your configuration management tool of preference can do it (Ansible, Puppet, Salt, …)
