I am running influxdb in a container with Caddy (as a reverse proxy) available at influx.quantaflare.com
I am using c# library to write the data (Datapoint class) - works well !
while reading the data, I create a client and SQL - just simple SQL with no parameters. I get error
(StatusCode=“Cancelled”, Detail=“Bad gRPC response. Invalid content-type value: text/html; charset=utf-8”)
here is my docker run if that helps
docker run -d --name influxdb -p 127.0.0.1:8086:8086 -v ~/influxdb-data:/var/lib/influxdb2 -e DOCKER_INFLUXDB_INIT_MODE=setup -e DOCKER_INFLUXDB_INIT_USERNAME=qfinfluxadmin -e DOCKER_INFLUXDB_INIT_PASSWORD=XXXX -e DOCKER_INFLUXDB_INIT_ORG=QForg -e DOCKER_INFLUXDB_INIT_BUCKET=QFBucket influxdb:latest
