I’m a newbie with Influxdb.
My intention is to switch from a MySQL database to Influxdb on my QNAP 451+ for storage of different measurements, e.g. coming from the photovoltaic system.
I started with different docker containers and used “latest” so I got influxdb2 2.6.1 release.
Independently what I tried, influxDB2 itself was running, I can access WEB-frontend via port 8086, I can select measurements, create buckets a.s.o.
The problem is with the “cli”. Starting “cli” in docker environment what ever I try, I get an error message
../# influx user list
Error: failed to list users: 404 Not Found: unable to decode response content type "text/html; charset=iso-8859-1"
Then I tried to install a qpkg-package instead of using docker container (many thanks to the MyQnap-team for providing a separate package with cli).
Result is the same → influxDB2 is running, behavior of “cli” still the same, absolutely identical error message.
I have no more idea, what could be the reason for that issue. And yes, I have seen an issue in github
https://github.com/influxdata/influxdb/issues/23036 but no comment there.
Many thanks in advance for any hint
Joerg
