I am currently facing some issues with influxdb
I am using influxdb V2.0.X and even though i have injected data into my database , my influxdb still encountered this issue which display fails to load tag values as shown from the picture even for the other databases. If anyone has a solution to this do guide me
Hi @KaiJ17,
Hope you are doing well! Could you provide a sample of your data? It might be the case that some loaded data was corrupted. Are you also seeing any warnings appear in the InfluxDB logs?
This is an example of injecting into my influxdb on node-red however it does not show any error on node-red but on influxdb it doesn’t show the tag values, I have tried reinstalling the snap of influxdb but even after reinstalling, it still doesn’t work.
Hi @KaiJ17,
I am a little lost on what might be causing this error. What version of InfluxDB 2.X is being installed by snap? Could you also provide a sample of your JSON data being converted into line protocol along with which fields are being made into tags
Hi @Jay_Clifford , sorry for the late reply , unfortunately i am not able to provide a sample of the JSON data being converted into line protocol along with which fields are being made into tags , as I don’t have it with me for the time being but however is it possible to contact you via email or so when i have the necessary resources, for the snap , I’m using influx db edge version nightly
