Hi
I want to exclude tag on a spessific output. So let sey i have a output to file that look like this
[[outputs.file]]
files = ["/data/raw/imu.json"]
rotation_interval = "1h"
rotation_max_archives = -1
data_format = "json"
in the actual file i get result like this
{"fields":{"value":30.85414165613187},"name":"raw__mqtt_sensors","tags":{"deviceid":"001","host":"telegraf","measurement_type":"sensor","topic":"test/001/sensors","ts":"1691495762465"},"timestamp":1691495761}
Under the tags field I get the key name “ts”. I dont want this tag to be written to file. How do I drop this tag when writing to file output. for other outputs I want this tag. The drop statment should only be for this spessific output.
