Dropping tag before appending to DB fails
Got an SNMP agent pulling stuff like so, but when I add tagexclude, it completely stops pushing metrics to database. I am using example from docs: telegraf/docs/CONFIGURATION.md at master · influxdata/telegraf · GitHub
Can anyone tell me what I am doing wrong? I want to remove the filtering tag I initially used from database
Here is my config
[[outputs.http]]
  url = "http://<DB>"
  data_format = "prometheusremotewrite"
  timeout = "15s"
  method = "POST"
#  tagexclude = ["destination"] <<<<<<<<< If I uncomment this, metrics don't push, but if its commented out its working.
  [outputs.http.tagpass]
    destination = ["medium"]
  [outputs.http.headers]
     Content-Type = "application/x-protobuf"
     Content-Encoding = "snappy"
     X-Prometheus-Remote-Write-Version = "0.1.0"
[[inputs.snmp]]
  interval = "60s"
  agents = ["udp4://<ROUTER_IP>"]
  timeout = "10s"
  version = 2
  path = ["/mibs"]
  unconnected_udp_socket = false
  community = "public"
  agent_host_tag = "source"
  retries = 3
  fieldinclude = [
    "*ifHCInUcastPkts", "*ifHCOutUcastPkts",
     "*ifInDiscards", "*ifOutDiscards", "*ifInErrors", "*ifOutErrors"
  [[inputs.snmp.table]]
    oid = "IF-MIB::ifXTable"
    index_as_tag = true
    [[inputs.snmp.table.field]]
      name = "ifName"
      oid = "IF-MIB::ifName"
      is_tag = true
    oid = "IF-MIB::ifTable"
    index_as_tag = false
      name = "ifName"
      oid = "IF-MIB::ifDescr"
      is_tag = true
  [inputs.snmp.tags]
    destination = "medium"
My bad it is working, it just didn’t show up in my dashboard because new metrics started appearing (without the label). You can test it by going to ‘Explore’ window in Grafana if thats how you visualise from your database
@fids224 thanks for sharing your solution and question with the community!
