I’m trying to automate bytesIn measurement from interface depending of my router’s model.
I wrote this query where $hostname and $model are already defined and working:
This is not working, I have this error: invalid: compilation failed: error at @6:21-6:22: expected THEN, got IDENT (RB2011UiAS) at 5:36 error at @6:21-6:22: expected THEN, got SUB (-) at 5:46 error at @6:21-6:22: expected THEN, got INT (2) at 5:47 error at @6:21-6:22: expected THEN, got IDENT (HnD) at 5:48 error at @6:21-6:22: expected THEN, got EQ (==) at 5:52 error at @6:21-6:22: expected THEN, got STRING ("RouterOS RBD53GR-5HacD2HnD") at 5:55 error at @6:108-6:112: expected IDENT, got IF (if) at 6:105 error at @6:108-6:112: expected IDENT, got SUB (-) at 6:107 error at @8:108-8:112: expected IDENT, got IF (if) at 8:105 error at @8:108-8:112: expected IDENT, got SUB (-) at 8:107
Thank you for your reply.
I have tested with your syntax and I have another error: invalid: compilation failed: error at @6:109-6:113: expected IDENT, got IF (if) at 6:106 error at @6:109-6:113: expected IDENT, got SUB (-) at 6:108 error at @8:109-8:113: expected IDENT, got IF (if) at 8:106 error at @8:109-8:113: expected IDENT, got SUB (-) at 8:108
As “$model” is already defined in variable like that:
from(bucket: "telegraf/autogen")
|> filter(fn: (r) => if "${Model}" == "RouterOS RBD53GR-5HacD2HnD" then
r._measurement == "snmp_interfaces" and r.hostname == "${hostname}" and r.if-name == "lte1" and r._field == "bytesIn"
else
r._measurement == "snmp_interfaces" and r.hostname == "${hostname}" and r.if-name == "ether1" and r._field == "bytesIn",
|> map(fn: (r) => ({r with _value: r._value *8}))
|> derivative(unit: 1s, nonNegative: false)
|> yield(name: "derivative")
And I have a similar error: invalid: compilation failed: error at @4:109-4:113: expected IDENT, got IF (if) at 4:106 error at @4:109-4:113: expected IDENT, got SUB (-) at 4:108 error at @6:109-6:113: expected IDENT, got IF (if) at 6:106 error at @6:109-6:113: expected IDENT, got SUB (-) at 6:108
Ah, I needed to scroll over more . Right now, r.if-name is being parsed as a conditional statement and an arithmetic operation (-). Becuase you have a dash in the property key, you need to use bracket notation instead of dot notation.
Try this:
r._measurement == "snmp_interfaces" and r.hostname == "${hostname}" and r["if-name"] == "lte1" and r._field == "bytesIn"
else
r._measurement == "snmp_interfaces" and r.hostname == "${hostname}" and r["if-name"] == "ether1" and r._field == "bytesIn",
Thank you for your time, patience and advices.
Syntax was, indeed, the problem.
Now, I have another error : invalid: runtime error @3:7-7:22: filter: type conflict: int != string
There is a way to have something like “echo” or “var_dump”. I’d like to have _value’s return. _value should be an integer and it seems to be a string.
I don’t think this is an error related to the type of your _value column. I think it’s an error related to the types used in your predicate. What version of InfluxDB / Flux are you using? I’m wondering if you’re using and older version of Flux that doesn’t automatically interpolate numeric values in strings (fixed in Flux 0.109) and your Model variable is actually an integer. If that’s the case, try this:
|> filter(fn: (r) => if "${string(v: Model)}" == "RouterOS RBD53GR-5HacD2HnD" then
I reimagined the way to have a dynamic interface then I change the Interface’s variable query instead of trying the add it in each dashboard query in Grafana, and, it works !
I’ve used your first reply like that:
